- bump image version to 3.30
- icons: add some more material design icons
- icons: remove obsolete hint-icons
- add "Material-Design" icons
- install our full "Material-Design" icons as default
- iconsets: use "Material-Design" icons for iconset-pkg0
- icons: remove obsolete icons
* aktueller
- bump neutrino version to 3.30
- themes: change text color on cursor to black
- icons: add and use pictureviewer icon
- usermenu: sort NI code to original code
- infoicons: simplify icon detection
- usermenu: allow testmenu in usermenu
- don't use casystem frame per default
- themes: change default colors
- add our new "Material-Design" icons
- infoviewer_bb: use just 1px for ca-bar frame
- iconsets: rename pkg0-iconset to "Material-Design"
- infoviewer_bb: enlarge ca_bar by 2 pixels
- infoviewer_bb: disable broken infobar_casystem_dotmatrix code
- channellist: remove obsolete NI-code
- infoicons: use OFFSET defines; increase offset between icons
- icons: move NI icons into categorized subdirectories
- cc_frm_header: try to fix clock; e.g. in timerlist
- configure.ac: change package name/version
- bouquets.cpp: remove linebreak from auto-epg console message
- capmt: fix include to get g_settings
- followscreenings.cpp: Fix option "always"
- capmt.cpp: Allow to disable the NI CI-Record workaround if option "usable CI channel while recording" set to "all channels"
- capmt.cpp: Codeing the NI CI-Record workaround closer to original
- helpbox: use a smoother color and a smaller height for separatorline
- themes: make Material Gray (dark) theme a bit darker
- themes: add Material Gray (Medium) theme
- infoviewer: move ICON_CA to the left
- cc_frm_footer.h: use proven COL_SHADOW_PLUS_0 for button frames
- locale: adapt last changes to our locales
