Im Online-Update gibt es NI 3.60, gibt es da evtl irgendwo einen Changelog zu 3.50?
Nightly 3.60
- pyrotechniker
- Box: Neo² Sat
Nightly 3.60
Panasonic TX-55CXW804
Neo² Sat | 160GB WD | Pearl DPF
Igel 4210 LX | Debian + IPC | HD+ HD02 | ORF ICE
Alphacrypt Light R2.2@o4a | Sky V14
- Has thanked: 70 times
- Been thanked: 119 times
Re: Nightly 3.60
So ein richtiges Changelog führen wir nicht. Ich habe dir aber mal alle Commits seit dem 3.50er Image zusammengefasst. Vielleicht kannst du ja was damit anfangen. Es wird aufsteigend gelesen.
Buildsystem:
Neutrino:
Buildsystem:
4523815 - ffmpeg-armbox: bump version to 4.1
0b9ec03 - LocalTV: fix build
2196458 - hd51: add symlink ld-linux.so.3 -> ld-2.23.so
e013d33 - skel-root/hd2: keep migration script in var-partition up-to-date
af73bdd - some more detailled clean targets
2559a70 - set up default parallelism
966a2cf - lcd4linux; try to fix user skin; ...
5c276d1 - snatching draw_line define from TangoCash
a7f0c6f - bootstrap.mk: rename blobs => var-update
2ab69f7 - neutrino.mk: re-sorting makefile
eb413c2 - signalize bootstrapped target with a flagfile in $(BUILD_TMP)
595f51d - update CMAKE variables
96d87eb - update README.md
05192c1 - prerequesites.mk: small re-sortings
8874364 - neutrino.mk: remove useless dependency
413aa6e - environment-build.mk: use "else ifeq"
5161beb - kernel-*.mk: use BOXARCH variable
2667f98 - busybox: prepare target for upcoming changes
968c81b - system-tools.mk: move busybox target up
4565b8c - reduce usage of BOXTYPE_SC variable to avoid mistakes with BOXARCH variable
71768c4 - busybox: enable getopts applet
6313fee - links: add patch to fix input device for cst hardware; thx to max
30cf9b2 - links: set german as pre-configured language
756ffba - neutrino.mk: align libstb-hal build
2888bc4 - links: reduce languages; fix wrong translation for T_SAVE_HTML_OPTIONS
0264109 - plugins: add links browser to hd2 (except boxmodel kronos_v2)
fc9d26a - neutrino.mk: avoid errors from neutrino's clean targets
0dca21f - fix handling of ./version file and neutrino's version.h
73dcbac - rootfs.mk: simplify .version file
4a48ac5 - rootfs.mk: more clarity what the targets do
9fe1472 - rename target targetprefix => target-dir
f86fa10 - unify install calls
4786fc8 - move creation for hd2 newimage flag away from rootfs-softlinks target
a7cd7b0 - move softlink creation for cross-libs directly to the corresponding target
0568886 - bootstrap: install include dir in same way as lib dir
70f00b3 - add targets for bzip2, fontconfig, pixman, cairo and harfbuff
91229a0 - system-scripts.mk: fix dependency for init-helpers target
c043a94 - rootfs.mk: small re-sorting of targets
853a228 - rootfs.mk: prefix rootfs-targets to avoid confusions
9b81d5a - add target for libjpeg-turbo 2.0.0 and use this lib on armbox
1fce8d5 - system-libs.mk: use new CMAKE variables
a0ed981 - environment: introduce CMAKE variables
913c05b - wpa_supplicant: fix install of pre/post-wlan0.sh scripts
be33ac5 - links: add space to 0-key
bc2e285 - add 'git rev-list' output to .version file
6f3ac07 - bump image version to 3.60
e1f4737 - update.mk: add wrapper target 'make pull'
0df078d - rename ni-git targets to ni-sources
d58bcab - rootfs.mk: remove non-working strip code for debug images
001f58f - add backup/restore for crosstool; based upon an idea by TangoCash
5986b06 - add small target to paint wonderful lines into terminal
d3594d8 - tuxcal/tuxmail: use init scripts from ni-neutrino-plugins repo
9e36d2e - move init helpers away from skel-root
41380e9 - skel-root/hd51: fix fstab description
8f8cf17 - system-libs.mk: fix indentation
7a5f646 - fix some file permissions
fc6c6c2 - busybox: enable id applet
da36868 - align smarthomeinfo target to changes in ni-neutrino-plugins repo
c29e2f7 - update.mk: fix update of plugin remote repos
73f5f8f - add Makefile.exmple; add default target (it targets to 'make all')
06a4e86 - skel-root/hd51: add missing sys_update.sh script
f608a81 - ni.mk: get sure the personalized target ist the last one before make rootfs
5f1a1ea - ffmpeg-arm: bump version to 4.0.3
7e9e750 - move update wrapper-targets to image-update.mk
b36e301 - move targets to install system-scripts to own makefile
2f81022 - rework makefiles; set up environment in several makefiles
e77e1ab - image-update.mk: clean up and resort
45de498 - move /etc/mtab away from skel-root
751df51 - move wlan0 scripts away from skel-root
11de4c9 - move ntpdate init script away from skel-root
6b86324 - move flash_eraseall wrapper script to archive-imagefiles/scripts
1679257 - system-tools.mk: fix indentation
c92654e - skel-root: clean up from empty dirs; let's create this dirs in targetprefix target
fc9a2d5 - image-update.mk: fix some paths
4024e83 - remove obsolete SOURCES variable
b9b7ffc - remove EPGscan plugin; new location is ni-neutrino-plugins repo
2350eda - remove vinfo plugin code; new location is ni-neutrino-plugins repo
df55eb3 - epgfilter: align to changes in plugin repo
f72ebe7 - remove epgfilter plugin; new location is ni-neutrino-plugins repo
ee20391 - add imgbackup-hd51 plugin to hd51-image
70dd923 - move doscam-webif-skin to archive-imagefiles
ed8d43f - remove pr-auto-timer plugin; new location is ni-neutrino-plugins repo
36cbacb - remove dropbox_uploader plugin; new location is ni-neutrino-plugins repo
c662f86 - remove stbup plugin; new location is ni-neutrino-plugins repo
d9a433a - remove emmrd plugin; new location is ni-neutrino-plugins repo
0afd858 - remove mountpointmanagement plugin; new location is ni-neutrino-plugins repo
2f9fbd2 - remove autoreboot plugin; new location is ni-neutrino-plugins repo
44633b9 - some more clean targets; add some more wrapper targets for image creation
9304e9d - expat: don't install docs
0701298 - Makefile: rework help target
c427d0e - crosstools.mk: remove obsolete make command
92b1f83 - crosstools.mk: more flexible handling
44ba6ee - busybox: enable hexdump
518f770 - remove symlink fbshot -> dboxshot
df7b63d - fbshot: rework target
36b92c5 - ca-bundle: try to get latest cacert.pem file
53f0313 - libdvbsi++: add patch to fix descriptorLength; thx to satbaby
c4b8758 - autofs: add latest patches from upstream
e40115f - rename CA-BUNDLE variables
9c0843b - move development archive variables to development-tools.mk
33b973c - ushare: a better upnp friendly name
00bfbfc - plugins.mk: clean up from unused old argets
0a41b91 - .gitignore: fix nohup file
c3fefd2 - .gitignore: ignore nohup files
a635001 - libmad: fix c/p errors
4a1abf3 - move stb-startup target call to the right place
b144df2 - add links webbrowser to hd51 image
917ee29 - fix links target; many thanks to max_10 ┗(-_-)┛┏(-_-)┓
bd333cc - add missing files for links webbrowser
0ba8411 - move files for links webbrowser to archive-imagefiles
902e0cb - sg3-utils: move init-script to archive-imagefiles
d1680a4 - remove wlan-drivers from buildsystem; new location is ni-drivers-bin repo
7008c23 - move driver/firmware softlink creation to driver/firmware target
1e1beae - move ntfs-3g softlink creation to ntfs-3g target
931a957 - move dboxshot softlink creation to fbshot target; do we really need this softlink?
934e3f1 - move openssl softlinks creation to openssl target
c1d82c7 - rename some variables
b17d6d6 - remove $(FLAVOUR) and $(N_HD_SOURCE) variables
b79e060 - change some patch calls
49f4190 - some small fixes for commit 3b393693080baafbb7047efb77de27038c01a226
d879a4b - plugins.mk: remove obsolete helper target
e1ae7c3 - fix copying of static-libs to rootfs
9b55ea8 - add some more clean targets
226eb7a - rename devel-tools.mk => development-tools.mk
76bc7a6 - openssh: bump version to 7.9p1
8c24b48 - change some patch calls; introduce $(MKDIR) variable
fae1dca - move host-tools to own makefile
4c2b901 - rename static.mk => static-libs.mk
33519c6 - old kernel is old :/
d049285 - switch to new self-made images per default
e9abfa1 - kernel-*.mk: small variables renamings
7710d0b - e2fsprogs: back to 1.44.2 for HD1
718cb96 - fix clean target
a0191fc - images.mk: move flash-image-arm target some lines to top
2cf472a - fix some more PHONY targets
fe41282 - fix some PHONY targets
1bcedbf Revert "- libsigc++: bump version to 2.10.0"
25fa62f - add some more more wlan drivers
b3448e8 - add some more wlan drivers
4ee4c54 - add some wlan drivers
7fa8139 - unify $(DEBUG) handling
4426652 - libsigc++: bump version to 2.10.0
1dc05f5 - u-boot: bump version to 2018.09
82f4c3a - mtools: bump version to 4.0.19
0a60827 - nano: bump version to 3.1
8217c58 - remove non-working old movieplayer playlist samples
c5c70f2 add IOzone Filesystem Benchmark
c66369e - libglib2 2.56.3
85b3505 - skel-root/hd2: install new myservices.xml to /var-partition
80489c4 - channellists: sync sat-names with current satellites.xml
7a49b33 - install new webradio files to image
0da0cf2 - xupnpd: align patch to fix build
0878d29 - server/update.php: fix image type; change to nightly
82087e3 - server/get-image.php: fix image type; change to nightly
4634356 - busybox: bump version to 1.29.3
1b657e1 - lcd4linux: fix backlight_standby for new samsung layouts
77f6dfd - lcd4linux: fix backlight for new samsung layouts
1026c16 - lcd4linux: align to new changes
1512fc1 - lcd4linux: fix path to pidfile
c8cacd6 - pr-auto-timer: fix logging
fabe027 - luaexpat: bump version to 1.3.0
00480d5 - expat: bump version to 2.2.6
ae9c5a0 - libcurl: bump version to 7.61.1
4a33031 - libglib2: fix build; align patch
7016726 - fix kernel build
1d0dfe4 - glib: "fix" build; this is not really a fix, but it covers up the warning: libgmodule-2.0.so.0, needed by ./.libs/libgio-2.0.so, not found
fa91731 - fix c/p error in 08586a9e4d74cc6c4ce1f1c4c6a77678f658353b
484dfab - pr-auto-timer: upgrade to v0.41
144580e - environment: add $(STRIP) variable
08586a9 - rework makefiles: fix indentation; ...
c14d9cc - neutrino: add zlib to dependencies
840f24e - pugixml: add patch to enable PUGIXML_HAS_LONG_LONG
3dc9c42 - autofs: remove my "debug" command
5b4243d - autofs: add pre-5.1.5 patches from https://mirrors.edge.kernel.org/pub/linux/daemons/autofs/v5
9c9c3ff - e2fsprogs: bump version to 1.44.4
fa6393d - ffmpeg-arm: add --enable-decoder=mpeg2video configure switch
a95dbc8 - confuse: bump version to 3.2.2
31dedba - zlib: align patches
b48f706 - wget: back to 1.19.2; ...
0764866 - bash-target: use apply_patches function to apply patches
47a11ef - archives-info: don't check subdirs in $(ARCHIVE) directory
1aed6ef - apply_patches: allow to define the depth for patch -p switch
050d37e Revert "- libtirpc: bump version to 1.0.3"
3ecc1da - busybox: bump version to 1.29.2
514190b - libgcrypt: bump version to 1.8.3
a3f525e - libgpg-error: bump version to 1.32
039274d - libaacs: bump version to 0.9.0
cf628b6 - libtirpc: bump version to 1.0.3
461cdb8 - rpcbind: bump version to 1.2.5
9233f60 - libite: bump version to 2.0.2
971707b - inadyn: bump version to 2.4
80f2e54 - hd-idle: bump version to 1.05
f36d533 - mtd-utils: bump version to 2.0.2
7cdfcc4 - strace: bump version to 4.21
7b45587 - mc: bump version to 8.2.1
3b8fe32 - exfat: bump version to 1.2.8
aa5fbd2 - less: bump version to 530
a240bff - nano: bump version to 2.9.8
6ed4a1f - gdb: bump version to 8.1.1
4977417 - libncurses: bump version to 6.1
594e829 - openssl: bump version to 1.0.2p
288c9f9 - coreutils: bump version to 8.30
f1c0f5d - libfuse: bump version to 2.9.8
6c8aeee - tzcode/tzdata: bump version to 2018e
0d0a048 - libvorbisidec: bump version to 1.2.1+git20180316
ba70e32 - autofs5: bump version to 5.1.4
7cf0056 - hdparm: bump version to 9.54
d052653 - bash: add patches to bump version to 4.4.23
a885ec0 - wget: bump version to 1.19.5
5e38c4f - alsa-lib: bump version to 1.1.6
bb9fac3 - e2fsprogs: bump version to 1.44.3
1cfed1c - libfribidi: bump version to 1.0.4
ac2efdf - pugixml: bump version to 1.9
14df43a - ethtool: bump version to 4.17
7dd8bea - openssh: bump version to 7.7p1
4818f2d - gptfdisk: bump version to 1.0.4
f5188dd - libcurl: bump version to 7.61.0
a575bcb - libpng: bump version to 1.6.35
973c33c - freetype: bump version to 2.9.1
d333504 - environment: add comment to explain NI_FFMPEG-variables
5c0a6ae - ffmpeg-arm: bump version to 4.0.2; align patches
251c34e - apply_patches: show filename of patch
6084c5e - kernel-arm: activate framebuffer console; update config to 4.10.12
6c9b6f5 - channellists: new matze and pathauf settings
ef95fec - libdpf: fix build from scratch
688992b - system-tools-extra: add target to build astra-sm
1c31b1a - pr-auto-timer: add Sky Cinema Uno to exlude-channels; thx tewsbo
7e0c7bd - dropbear
069e6f7 - neutrino.mk: add our api keys
a14bb65 - dropbear: bump version to 2018.76; remove obsolete patch; fix build
e6478ce - openvpn: bump version to 2.4.6
0fd86e1 - hd51: don't cut the multi-image (thx to flk)
1649a62 - plugins: align LocalTV target; add target to install webtv-scripts
7b3592d - libxml2: bump version to 2.9.8
e1f9a9e - libogg: bump version to 1.3.3
e89f31f - e2fsprogs: bump version to 1.44.1
1cd2d5a - libcurl: bump version to 7.59.0
8fc2452 - openvpn: bump version to 2.4.5
977948a - channellists: update matze settings
165f27a - neutrino.mk: fix libstb-hal dependencies
77b06d2 - fix d43293e9f3d641130c65ec9703708587c942bba9
d43293e - add some goodies
10258d3 - libdvbsi: remove obsolete patch; code is upstream now
81e2675 - fix url to libdvbsi++ repo
b49bd48 - fix url to tango's libstb-hal repo
95ac248 - fix build with host gcc7
7891da1 - bump some libs
b218240 - lua: bump version to 5.2.4
fc675e4 - move services-script from skel-root/ to archive-imagefiles/scripts
c6491d2 - skel-root: allow options to service calls
368e1a5 - channellists: new matze settings
8d6e63b - system-tools: simplify ethtool build
f3185d7 - e2fsprogs: bump version to 1.43.8
691e9de - system-tools: add target to build ethtool; enable ethtool for hd2 and hd51
b232f8e - ffmpeg: update configure switches
4bb4509 - ffmpeg-arm: fix dependencies
0fdaf36 - ffmpeg-arm: enable libfreetype
13df0a3 - ffmpeg-arm: align to openpli
0e76ca5 - add needed ffmpeg patches; taken from DDT
be8c9b1 - move ffmpeg target to own makefile; split into cst and arm
a9a98cf - environment.mk: add define to apply patch sets; shameless stolen from DDT
c32f58a - neutrino.mk: remove possibility to build plain tuxbox neutrino
aed11e6 - neutrino.mk: add explicit deps for libstb-hal to avoid circular deps
9fc65ea Revert "- busybox: bump version to 1.28.0"
cce3a82 - update.php: allow nightly builds in online-update
5d5c87d - dvbsnoop: switch to DDT-repo; it contains all usable patches
0dfe404 - busybox: bump version to 1.28.0
2efb66e - system-libs.mk: sort ffmpeg-switches alphabetically
9215ecc - add dvbsnoop to hd51 image
39ceda4 - system-tools: add dvbsnoop target
1920db7 - remove obsolete code
9b04fbf - personalize: fix stupid copy/paste typo
eb7455f - personalize: try to fix command line errors
5ed9321 - prepare for nightly builds
280f023 - add unpatched ffmpeg master branch as requested
d71b483 - update.mk: fix dependency for update-ni-git target
6225a44 - clone rtmpdump-repo only once
1ec376b - image-update.mk: cleanup settings-xml's from non-printable chars
b507089 - move alsa-lib target away from gstreamer.mk; this target is not only gstreamer related
5e21f30 - neutrino.mk: disable gstreamer; use eplayer in libstb-hal by default
7e6dac1 - config.example: clarify comment for hd51
1a34da7 - Makefile: small fixes in printenv target
07dcbe0 - remove CROSS_BASE variable; use CROSS_DIR instead of this
efbc73f - small format changes
52111cf - rename TARGETINCLUDE => TARGET_INCLUDE_DIR
9e9a33c - rename TARGETLIB => TARGET_LIB_DIR
57e67d1 - rename STATICLIB => STATIC_LIB_DIR
bda3051 - rename TARGETPERFIX => TARGET_DIR
45c6981 - rename HOSTPREFIX => HOST_DIR
4374407 - update.mk: don't auto-pull from tuxbox remote-repo anymore
d4eb4cb - webtv-setup: fix compiler warnings
5650194 - webtv-setup: disable possibility to setup livestreamScriptPath ...
c746c25 tuxtxt: fix global buffer overflow line 4753 in tuxtxt.cpp if Char is 0xF5 or 0xF6
5a41e95 add support for wwio bre2ze4k
33d34fe display clock on segment display too
a2e2b87 - fix moving of webtv/webradio xmls
4210c12 - data/scripts: fix permissions for some scripts
dceffe3 - update and rename migration script; execute migration script before loading config
f890ebf - yWeb/yparser: complete handling of directory defines
b1fcbed - remove unnecessary install-data-hooks
84f2233 webtv: switch default webtv paths from CONFIGDIR to WEBRADIODIR_VAR (specified by configure)
0b93981 webradio: switch default webradio paths from CONFIGDIR to WEBRADIODIR_VAR (specified by configure)
b10abeb webradio: create necessary data directories at build time and put sample file in it
939b1dd webtv: create necessary data directories at build time and put sample file in it
ba525b5 - webtv-setup: remove //NI tags
3c9db35 webtv/webradio: move defines for webtv and webradio path to a more appropriate place
6979066 screensaver.cpp: add one more event to filter
fa73c27 cc_frm_clock.cpp/h: fix incomplete result of isRun() methode
eaefdb3 cc_item_text.cpp: avoid evaluation within parameters
f9145a6 cc_item_text.h: declare unnecessarily protected variables as private
badb45b src/gui/screensaver.cpp: avoid create clock instance if not required
830f37f screensaver.cpp: start clock only if not running
fac08ce cc_frm_window.cpp: fix possible oversize render with maximum screen settings
6b58f65 Revert "infoviewer: force repaint of text fields"
b503072 cc_item_text.cpp: add missing paint state after rendered text box
fa6f42b src/gui/widget/textbox.cpp: try to fix possible background handling
88b9c78 - streaminfo2: change name Picon to Logo
6c6ef9b streaminfo: show techinfo in TS_MODE if channelist is empty
307eea9 streaminfo2.cpp: show resolution in TS_MODE if no channel is tuned
9659825 activate streaminfo2 for non COOL_HARDWARE
47949ba - imageinfo_ni: align to new version handling; split image and neutrino
ff8a98a - minor modifications in version.h
d99d5d5 - configure.ac: get ver_micro directly from git repository
c6c57db - bump neutrino version to 3.60
ad75c3c - acinclude: unify and simplify latest tmdb/omdb/yt/shoutcast things
4916869 - yWeb: better positioning inside yInfo
750f172 - yWeb: use percentage scaling for yInfo to always get fullscreen
85b2e57 - yWeb: add favicons, manifest.json and browserconfig.xml to yInfo page
fbcf452 - yWeb: small changes in NI yInfo; use material colors
bb60800 - fonts: add Apache Licence for Roboto font
f4ff1c0 - fonts/Makefile: better structure
9604d04 - vusolo4k: simplify and unify code from commit 59f48036674e482236336f18b440189e83bd013b
30226a0 - add support for VU+ Solo 4k
fcc78ad - settings-manager: remove NI tags
51c670c - acinclude: simplify commit 48de97c34ff4216a93814a137ad99302b3592ab7
1a12ee5 add first experimental support for ax hd60
0d9e761 - yWeb: remove support for outdated dboxshot binary
041f56e - infoviewer: fix display of frequency for terrestrial channels; thx to Janus
0e114b5 cc_frm.cpp: add missing condition within paint methode
4f44170 cc_item_text.cpp: fix missing pass through of var cc_allow_paint
6d11033 lua API: change to version 1.80
0f96e79 radiotext.cpp/h: add signal to implement slots after decoding of text lines
4adec29 helpers.cpp: reduce debug output in downloadUrl()
edc506f add function to dump current epg mappings
2c66e16 allow epg mapping for all channels, add logic check for converter
29fe174 supplemental to bddc03b06619bc427f5e7675307f29d37c996473, fix typo
33f6a38 supplemental to b1f6d3531a0eaf0fea8bdd939ee679a4e219fd65,fix logic
49fdeee add E2 to NMP EPGMapping converter
73260e5 add option to map xml epg to normal channels
d7795f2 fix typo, use function for time diff
7e5029e fix xmltv time offsets
08b8505 fix xml utf8 detection
766e65b infoviewer_bb.cpp: suppress tuner icon in ts mode
d4a7cfb - colors: highlight marked items a bit less
d24455f - cec-setup: fix segfaults on non-ARM_HARDWARE
7a698ee - zapit/getservices: fix currentservices.xml format for cable and terrestrial
4b2b3b9 - imageinfo_ni: show localized image type
551cd5f - identify self-made images
1ecb3e8 fix capmt wrong debug output
806b4c7 streaminfo1.cpp: show resolution in TS_MODE if no channel is tuned
1d6b956 - initial-settings: new matze settings
0853eb0 move external volume control to internal volume/mute handler
a080075 - update backup script
9630df1 supplement to commit 72badc7; fix scale of box width
8c4badf hintbox.cpp: fix scale of box width
b0dc739 - lua: fix hintbox/messagebox default width
e9bfb9e - moviebrowser: remove unnecessary check from hintbox in showYTMenu() function
8fc2a51 mb.cpp: fix locale for YT
da864d3 - cec-setup: fix item mode when switching cec on/off
8e9c4a7 add option to regulate audio systems volume via CEC
ae6fa1e correct some CEC Events
0de4abd fb_accel.cpp: fix the fu..... gaps on arm gui
3eaac8f remotetimers: fix fetch from other box
3e9c43b scansdt: more checks if the same TP
34dfd59 - update dat local (thx Janus!)
7aaa4df add menu hint to commit 15d0dbd
d4d3343 - enable SDT-Scan by default; minor changes in english.locale
91600db add/reenable background SDT-Scan to update channels while zapping around
b9105e0 - cables.xml: update OstTelCom GmbH; thx to elstablo
0a91eb8 - remove /NI tags from some picked lines
187acdc src/daemonc/remotecontrol.cpp: fix possible code errors
dc32ecf - neutrino: align our startlogo handling to changed CFrameBuffer::showFrame() function
ecb1190 src/driver/fb_generic.cpp/h: use methode showFrame() as bool function
d2d4643 - lcd4l: fix whitespace errors from previous commit
2716642 lcd4linux: convert polish letters
1038b01 - lcd4l-setup: use better readable enumeration to handle g_settings.lcd4l_display_type
32fab6f little update lcd4linux
a463644 fix segfault in standby
ff1c17d - data: add myservices.xml sample
1c50d85 - data/Makefile.am: better readability
f04e70a - initial-settings: re-activate initial-settings and name matze as requested
803afbb - initial-settings: replace existing stuff with matze settings
829c3a9 update satellites.xml
9855748 - movieplayer: more readability in code to search for livestream script
cbe40d0 - movieplayer: fix search for livestream script in webradio mode
abf2fe0 upnpbrowser.cpp: paint picture when reentry same folder
e860406 - multimedia-setup: re-organize menu
4c9ae39 - webtv/webradio: cleanup user's files; add dummy sample only
e8820fe - webtv/webradio-setup: fix webchannels_auto() logic
e0246f3 - webtv-setup: remove useless check in webchannels_autodir() function
9b28e96 - webradio: add possibility to auto-load webradio files
49a3143 - webtv-setup: implement webradio-setup into webtv-setup code
b06fdf8 - neutrino: introduce WEBRADIODIR and WEBRADIODIR_VAR
53933a3 scansdt: typo
e683e57 scansdt: check dmx
2877c27 scansdt: add update without SDT SID
685c42a -webtv: fix segfault while reload
f883d5c infoviewer.cpp: prevent segfault if framebuffer is already deactivated in standby mode. (race condition)
310e3f4 - icons: add webtv and xmltv hint icons
09903e1 - neutrino: add xmltv-setup
b5a4317 moviebrowser: workaround fix for delete fileinfo from gui list wit epginfo1 with whitespace
9e709ab - webtv-setup: move LIVESTREAM_RESOLUTION_OPTIONS to CWebTVResolution code
dadc1cc - webtv-setup: init filebrowser only if needed
a7c8e4c - webtv-setup: add possibility to edit webtv-file manually
10a7a20 - webtv-setup: just code reformatting (using astyle)
235ee5c - webtv-setup: add possibility to enter webtv-file manually
1f49160 - webtv-setup: show hintbox when reloading channels
1305b5d - webtv-setup: minor changes in changeNotify() function
62eeb90 download/cache xmltv logo only if no local logo already exists
3955d83 adding caching xmltv logos
b1dc889 cleanup LOGODIR_TMP at start
53b767f add some threadsafety
3a49fa3 pictureviewer: fix segfault if no channelid is present
808dff3 speed up starting neutrino while loading xmltv logos, the better way
7914fb9 Revert "speed up starting neutrino while loading xmltv logos"
a4cd0c8 cleanup COVERDIR_TMP at start
abf7116 -src/zapit/src/channel: fix warning: this statement may fall through [-Wimplicit-fallthrough=]
6c904ed screensaver.cpp: add 2 more events to filter
032c374 - locale: fix CSTLink (HDMI-CEC); it's not only CST anymore
1c59a17 - rename COVERDIR => COVERDIR_TMP
2d3f66a - helpers: rework new random-functions to get the code more reuseable
a365bd6 - webtv-setup: show autoloaded webtv files as inactive menu items
1876460 - locale: fix webtv locales; it's not only xml anymore
89d203e - webtv: simplify check for autoload directory
4e8f173 speed up starting neutrino while loading xmltv logos
a3a77b2 - webtv-setup: allow to load *.m3u and *.tv automatically
f911059 - yweb: try to fix oversized channellogos
94a59b8 - locale: fix menu.hint_lcd4l_support locale
394d87c - locale: fix menu.hint_key_standbyoff_add locale
2435419 - locale: add missing lcd4linux locale
3598a95 - lcd4l: use better readable enumeration to handle g_settings.lcd4l_display_type
ab8a9b2 - lcd4l-setup: restart lcd after brightness change
a20bd2d - lcd4l: fix cherry-pick
74f1256 lcd4linux update, add brightness settings
52b5d06 - lcd4linux: fix path to pidfile
c09a167 lcd4linux: fix add display type
43892e3 lcd4linux: add display type
9aa99cf - cables.xml: update Unitymedia; remove obsolete Unitymedia BW
3eb09d6 fix infoviewer
a4789ae armbox: rework AC3 and DTS passtrough
3f35d40 - controlapi: fix xmltv.m3u output for channels without logo
d5c3c9a - controlapi: minor changes in url creation in xmltvm3uCGI() function
a68703b - controlapi: reformat CControlAPI::xmltvm3uCGI() function; no other changes
f08d1f9 - pictureviewer: search for e2 picons in LOGODIR_VAR and LOGODIR too
2c1e995 adding support for E2 picons
477264a use alternative logo if present
2ca0e70 fix logo url, white space in xmltv.m3u
8709654 read logo marker in m3u files
f474e60 adding download helping function
c788e53 adding alternative logo for webchannels
e6408da arm ci clock fix
2e064d7 plugin integration main menu added
8d49b17 data/bad_package_pattern.list.sample: update and resort samples
34f6661 movieplayer , bouquets expanded to rtp:// and https://
ad7d094 - neutrino: add localized bouquet names
99cad42 - infoviewer_bb: update ca-bar
13ab6e9 src/gui-neutrino/lib/xmltree/xmlinterface.cpp: fix build when compiling with -Werror
1e0eaf7 Revert "- xmltv: move code to read xmltv.xml to the already existing place where epg is read"
841b6ef implement own tmp function / satify compiler
aa5faec - miscsettings-menu: read xmltv too when user requests a re-reading of epg
1239c13 - xmltv: move code to read xmltv.xml to the already existing place where epg is read
5dae193 - rename g_settings.webepg* to g_settings.xmltv* because it is XMLTV; see http://wiki.xmltv.org
04c41bf - eitd/sectionsdclient: unify new code and call it as it is ... it is XMLTV; ...
340a728 fix repeating remotetimers
632dfd2 - webepg: align new keys/values to the existing keys/values
0d94093 add settings for xmltv epg
8ad9f2e add option to read (online) xmltv epg
8c5b400 fixes for xmltv epg
f29a05a cleanup
c70f701 - zapit/bouquets: minor format changes
788b0ad - fix compile warnings from previous commit
fb19c18 prepare for online webchannels lists / fix epg
f2c2086 fix possible segfault
f47bbbf src/driver/fb_generic.cpp: unifiy path search in showFrame()
e3c6a54 src/driver/fb_generic.cpp: add possibility to use images with full name
cce09cc - xmlinterface: fix compiling for CST hardware
08855c2 - add gzstream.h to fix 4bcce912b248fd21018c45dfe2c2801367e4178c
4bcce91 add reading from gzipped xml files (xxx.xml.gz)
2179bc9 - zapit/bouquets: format changes
3d28911 more time for shutdown message
2f79c50 small fix in bname
1b0300d - audioplayer: remove some code; since 2588700 it's to find in helpers.cpp|h
e7672da src/gui/components/cc_frm_footer.cpp: fix assinged vector content
20ab649 cc_frm_footer.cpp: avoid possible crash if content[i].button = NULL
c16e5e6 cc_frm_button.h: expand getButtonDirectKey() for item id
b943f99 src/gui/components/cc_frm_footer.cpp: add member getButtonLabel()
c8e85c3 src/gui/components/cc_types.h: fix default key for button labels
b14124b avoid segfault with saved tvg-id
66cf480 supplemental to a22bcffd67d0bd7c32badcc9a7a8c55f54398ce1
2588700 adding some curl helpers
a7be95b add option to load E2 & M3U iptv lists directly as webtv
7dbded9 - channellist: re-allow switching bouquets in zaphistory/current_transponder mode
6a996e6 - neutrino: new defaults for epg scan; scan all favs in standby mode
0a109fc - neutrino: hopefully last fix for b02d2aa3910d2870cf45365d7149f9fb231edb12
d126829 src/gui/scan.cpp/h: add more plausible caption for user canceled scan
1b0ea06 locales: add cancel message for canceled channel scan
46f543f - movieplayer: don't wake up screensaver with ignored msgs
5395c04 - screensaver: move code for ignored msgs to screensaver code
b02d2aa - neutrino: disable some items in record mode (version 2)
5246233 - menu: add condition to enable/disable items in record mode (version 2)
3537010 - scan-setup: rework/unify shortcuts (thx to Janus)
2154812 Revert "- menu: add condition to enable/disable items in record mode"
e60350c - neutrino: disable some items in record mode
5bc3332 - menu: add condition to enable/disable items in record mode
c6bab8b - movieplayer: fix display of timeshift stop dialog ...
dae8f4c - movieplayer: fix vfd message when timeshift is startet in paused mode
6ac26b2 - neutrino: fix auto-delete code
4df740d - movieplayer/record: move timeshift deletion code to moviebrowser ...
6cbad3c src/gui/imageinfo.cpp: add entry for operating system
27872b9 - cables.xml: update Antennengemeinschaft Göltzschtalbrücke
7c555a7 src/driver/fb_generic.h: use unified define for fb device name
c7e63ad - user-menu: disable timeshift item if timeshift is already running
b2649b0 - record-menu: allow to exit with RC_stop, when no records available
6f7ff2a - movieplayer: signalize zap tries with key_quickzap_up/down in timeshift mode
d0e071b - locale: better locale for zap tries in movieplayer
58fc639 - locale: better locals for record menu
df96507 - record: show record-menu after no-records-hint; ...
49768df - usermenu: better locales for record/timeshift items
78943d0 - record: add space between title and duration in record messages
e7ea802 - usermenu: add timeshift item to blue usermenu; small resort to get colorkeys sorted
984e187 - channellist: move avoid-zap-in-movieplayer-mode-message ...
d03f201 - movieplayer/record: stop playback of timeshift when zap to another channel
8890a26 src/driver/record.cpp: avoid possible build error 'unused-but-set-variable'
8409532 src/gui/timerlist.cpp: use more plausible SaveScreen methods
d2be7e0 src/gui/widget/menue.h: add plausible alias for disableSaveScreen() method
886140c src/gui/movieplayer.cpp: check return after playback start
440c2c8 - locale: update slovak locale (thx to EnoSat)
901a543 - neutrino: fix bouquet align when zap via history or current transponder list
337a2ba - record: differentiate between timeshift and record in AskToStop() function
f86e711 - record: set TSHIFT_MODE_OFF when stopping timeshift
81ac37d - record-setup: minor changes in timeshift-setup
576fde6 - movieplayer/record: try to fix timeshift stop; ...
b913a04 - epgplus: signalize zap tries while movie playback
fe95ea7 - user-menu: allow SNeutrinoSettings::ITEM_EPG_SUPER and SNeutrinoSettings::ITEM_EPG_LIST in movieplayer-mode too
7a4397b - epgplus: move CEPGplusHandler::exec() code to end of file; ...
3fcffe8 - movieplayer/infoviewer: simplify call of showMovieInfo()
6b9cb7f - epgview: fix CEPGDataHandler::exec() in timeshift mode
5658811 - movieplayer: remove NeutrinoMessages::SHOW_EPG handling from handleMovieBrowser() function
deb4313 - user-menu: enable SNeutrinoSettings::ITEM_EPG_INFO in movieplayer-mode too
3dc2c47 - epgview: rework CEPGDataHandler::exec() to get work in movieplayer-mode too
69458b5 - movieplayer: move code to display movie-info to an own public function
4d5ab97 - timerlist: fix display of gui-rests when adding a new remotebox
2185a32 - moviebrowser: enable search in sms mode by default
cd6d3bc - neutrino: add additional key to leave standby mode; unify standby locales
a5a2dcf - moviebrowser: party revert caa8b68b170a395e446f3898f91ba09d9d8bfb80; ...
03937ee - moviebrowser: small changes in menu locales; display hintbox while saving movie info
58c7d2d - moviebrowser: re-add by mistake removed boolean value got_start_pos
70cbc65 - menu: fix return value of getSelectedLine() for RC_timeout and RC_setup
9b0a37b - moviebrowser: set focus in StartPosSelectionMenu to last play stop if it exists
caa8b68 - moviebrowser: add subheader to main window to avoid gui-jumps; add left/right icons to header
13d047f - fix build
2ad02fc - moviebrowser: fix sorting
dc735ca - moviebrowser: allow to display record time
98b00c1 - moviebrowser: fix display of mp_movie_info->dateOfLastPlay
208eb90 - epgview: fix display of mp_movie_info->dateOfLastPlay
08a4e95 - movieinfo/moviebrowser: do not use any fake date to fill dateOfLastPlay and file.Time
6b76559 - keybind-setup: try to fix return value of msgbox when new rc is not confirmed
f895e0d - icons: make marker icon for sd-channels a little darker
ff1db4d - channellist: fix display of very long channelnames
114bc9f - channellist: allow to show resolution icons
2422cec rcinput: try harder to reacquire input device
fc42128 tuxtxt: remove unused var_screeninfo.yoffset (always 0)
1506b35 tuxtxt: fix framebuffer blitting for SPARK
0f22e74 tuxtxt: use one global CFrameBuffer variable
bf5c4ce - neutrino: create LOGODIR_VAR at start
59070b3 - moviebrowser: check for channelname too to change channellogo; ...
21638a1 - audioplayer/screensaver: refresh screensaver picture when title was changed
baca01d fix framerate 29970 signalisatiom (by bazi98)
923fdb0 - screensaver: try to fix display of audiocovers <-> own pictures
9000b01 fix signalisation bitrate 599940 (by bazi98)
cd40b57 correct length in movie-info during "stop"
3c94d8d fix 5b190db (disable CEC standby after flash)
ff875e5 disable CEC standby after flash (armbox)
514b7b4 - screensaver: fix df30f2957f5b15268450573a43846cb40dd3fa40
6718444 - screensaver: allow to switch clock <-> picture while runtime
1c67a57 - audioplayer: remove all covers when playback is stopped or title is changed
61d3083 - remove cross-team settings
5acb687 - radio-favorites.xml: add 80s80s DM as a sample stream
76507f3 - audioplayer/screensaver: add gui switch to use covers as screensaver
a9372cc - radio-favorites.xml: use larger station-logo in sample entry
df30f29 - screensaver: paint blackscreen.jpg before starting screensaver to get sure we have a blank screen
2f5de64 - audioplayer: don't remove station-logo immediately; ...
94a0ad5 Revert "src/gui/screensaver.cpp: simplify painting images"
1e601be src/gui/screensaver.cpp: ensure usage of transparent background for clock
7339212 src/gui/screensaver.cpp: remove call of showFrame()
255945b - internetradio: clear playlist before loading a new one
87dd0fa - audioplayer: fix station logo handling for icecast
f955366 src/neutrino.cpp: fix possible compile error
fe8313c src/neutrino.cpp: hide dev/api keys when keymanage is disabled
c77ce41 src/gui/screensaver.cpp: simplify painting images
43c7051 Screensaver: try to fix background
e42b1ce - helpbox: fix cc8ac7d; build was broken
cc8ac7d - helpbox: replace fixed value with a scalable one
1f89d39 pzapit: add get video format
ae944c5 pzapit: add set and get OSD resolution
d76ce98 imdb: Fix an issue on changing of imdb key during runtime.
e36df1d pzapit: format help text
b11ecea - lcd4l: remove BP/NI defines
3a82bfa - lcd4l: move lcd4l-code to driver directory
6448ba0 hdd_menu.cpp: add support for sgdisk; fix sfdisk usage
6bb6047 - epgplus: fix shadow for scrollbar
59a9572 src/gui/epgplus.cpp: add missing home handling
2610d43 - infoclock: add hack to control logomask plugin
e515f87 imdb.cpp: fix parsing google file
b2ef15f icons: fix wrong icon name, update icon face
3bb137d data/bad_package_pattern.list.sample: add krb5
467bc35 - epgview: disable unused CEPGRateBanner code
79c72f6 - epgview: small fixes in imdb text arrangement
a873e5b - tmdb: show decimal points in rating stars
be65591 - epgview: re-use our smooth starbar to signalize decimal points in rating-stars
4015d0c - neutrino: remove our api keys
c85c75b - moviebrowser: remove NI tags
82ffe57 - epgview: sync with tuxbox; our code was completely taken
8cae61b src/gui/miscsettings_menu.cpp: fix possible compile error
ef03c4d src/gui/epgview.cpp: optimize text arrangement for tmdb/imdb
da603e8 - epgview: use OFFSET define instead of fixed value
b758bae src/gui/epgview.cpp: rework online epg database handling
3c47746 src/gui/epgview.h: add class to create star bars
9833dfc src/gui/epgview.cpp: update license text
d56fe91 ytplayer: apply enable option for internal YouTube playback
7d6a4db Api keys: add class instead single functions to check api keys
22aedc0 neutrino.cpp: add defined api keys into online service settings
f2d3b96 setting_helpers.h: add generic function for api keys
1af35f3 imdb-support: renamed imdb->omdb
d84c5a2 CIMDB: load api key from settings
4b9058d CMiscMenue: apply api key options
fb49917 CMiscMenue: adapt to new dev key definies
0423ed4 misc settings: add missing locals and settings variables
ac92d2a CIMDB: clean up
7727d5f src/gui/videosettings.cpp: disable fade option for AX51/Mutant
8f32d42 src/gui/videosettings.cpp: don't show entry for vf key settings
74f1f2f widget/menue.cpp: avoid paint of toggle buttons with more than 2 opts
5a2b120 src/gui/test_menu.cpp: doc corrected
ebffa80 src/gui/widget/msgbox.cpp: add missing handling of RC_home message
9c5c4d5 data/bad_package_pattern.list.sample: add zsh
7d920e1 configure: add options for online services
35fa18c - neutrino: use WEBTVDIR as default for g_settings.livestreamScriptPath
5e65dca videosettings: fix set and get video_43mode
54551dd - neutrino: remove NI-tag from g_settings.network_ntpserver
e3077a0 data/bad_package_pattern.list.sample: fix typo, add webmin
345d38a theme Gray-Blue: add 'enable' trigger button
fb1f2b9 themes Olive3.0, Neutrino3.0: use more contrast for trigger buttons
bda07ee pzapit -gm: reactivate get current TV/Radio mode
62e3379 color buttons: small changes on color
1c078a1 - icons: better differentiation for new sliders
0a12bfc - remove webtv scripts/xml's; you'll find this stuff in plugin-repo now
b7d59d8 fix epg dir, strange static behavior
9c1fb73 - locale: small changes on themes locales
b4849c9 - themes: don't show inactive item to visualize migrated theme
284082f - yWeb: activate pos and recall keys on remote controls (thx to DdD)
9284000 - icons: small changes on new option sliders
0e64c1f - icons: rename important.png => marker_warning.png because it doesn't signalize important stuff, but warnings
7b149f3 - icons: add default icons for new option slider
3a477d9 - themes: add default theme
1ebe774 Icons: change check markers, rename to dialog on/off, add update marker
332df34 themes: add some theme relevant trigger buttons
9be66d8 Revert "COsdSetup: kill instance of osd_menu_colors"
f0f4698 menu: add optional usage of toggle buttons to visualze options
84612b7 src/gui/osd_setup.cpp: use CMenuForwarder instead CMenuDForwarder
98a962c getValue(void): remove multiple declared members
8b055d5 themes: add locales for theme reset
6a36a75 CThemes: visualize migrated theme after possible update
0344962 CThemes: add default theme from config and migrate theme settings if needed
2004017 CThemes: rename member readThemes -> showThemesMenu
1aaaf8c CThemes: visualize current selected or applied theme
dd329ce CThemes: inherit CColorSetupNotifier into CThemes
8498f29 themes: set default theme instead static colors, but hold fallback
06bd351 themes: add setting entry for theme name
bc794ba CFrameBuffer: add more possible icon paths in order of priority
d1a6bb8 Color theme setup: re sort some entries, remove some separator lines
34300a2 Progressbar setup: add missing caption for global settings
75fc656 - remove NI-tags from progressbar color code
d2ab30f colorchooser.cpp/h: add separate init method
411c3f0 Color setup: add button bar
820d07c CColorChooser: fine tune position of color rate
3c1dfbb Color setup: Show color number in preview.
e8f3ff1 Color setup: align to general window composition
0da7bd9 CColorChooser: use unified variable vor window font
7a51a39 color setup: Visualize color rate
a3dc9cc locales/fonts: add global window font
9d02827 - english.locale: some more minor corrections
f62503e - deutsch.locale: Fix some english hints
b48f9e2 - locale: minor alignments; mostly capitalization fixes in english.locale
27011e6 - locale: minor changes in timing.infobar locales
e0be304 infobar timout: add member to get current timeout modes
89770ba infobar: rework infobar timeout behavior
803b341 Imageinfo: resort image and gui relevant entries
afaa9d2 - channellist: signalize zap tries while movie playback
b2830a9 - channellist: try to respect users timeout settings when hiding infobar
c8e7ddc CCDraw: add debug output to identify errors in relevant item types
d188811 CCTypes: outsource type variables and methods into own inheritable class
dc21b3d src/gui/widget/menue.h: fix possible compile error with older compliers
c747e37 - nhttpd/controlapi: make CDATA attribute in xml output switchable to fix xmltv.data
adb8029 Revert "CMenuOptionNumberChooser: expand localize functionality for any number"
3acd36b CMenuOptionNumberChooser: expand localize functionality for any number
db458bc - nhttpd: re-add CDATA attribute to xml output to keep compatibility with some plugins
e895e25 fix fontrenderer segfault (thx DBoxOldie)
52f5fa1 - neutrino: remove NI tags from usermenu settings
e138d8a src/gui/channellist.cpp: use channellist object on stack
9968eee not generic code
bb105c5 src/zapit/src/capmt.cpp fix possible segfault
6b449f5 fix webif xml encoding, part 2
0d4c7b2 fix webif xml encoding
8f2d530 - msgbox: add missing handling of RC_home as cancel key
0f75bb3 src/gui/epgview.cpp: small indent fix
4550ba4 src/gui/components/cc_frm_icons.cpp: initialize of dimensions dependently from added icons
733be3c fix copy, supplement to last commit
6264abf supplement to a04e899d44ad94c0f280183e254d264ce7e6c882 , memcpy don't work ok with std::string
85d012d src/gui/widget/menue_target.h: ensure init of valueStringTmp
fb5ee73 CNeutrinoApp: ensure clean up of screen in standby mode
4a952b1 Revert "neutrino: do not clean up infoviewer"
a84c0a1 - channellist: re-add list of recordable channels (while recording) to key_current_transponder
8dbd419 - channellist: move zaphistory/current_transponder handling into sepatate function
12a67c5 - channellist: avoid switching bouquets in zaphistory/current_transponder mode
9034fd3 - channellist: simplify key_zaphistory/key_current_transponder handling
e8b9104 - neutrino: simplify key_zaphistory/key_current_transponder calls
b0c367a - keybind-setup: sort mpkeys more consistent
2539cfd - infoviewer_bb: fix ecm parsing
6a5aea5 pzapit: fix get 4:3 mode
c2b76ae - fix 5152d34b8b03821c301f85c318a1edf21ac03eac
5152d34 - daemon-control: update
06e2e58 - cables.xml: update OstTelCom GmbH
21e0f96 src/gui/components/cc_frm_icons.cpp: fix typo, add missing include
4d5ebde data/bad_package_pattern.list.sample: add more filter entries
5f8722d CComponentsIconForm: add member to add any number of identical icons
c5f6ecd cc_frm_icons.cpp: add missing call of addIcon();
efa5621 - channellist: show choosen channelnumber on vfd while numeric zapping
c06c984 - eventlist: re-add RC_0 to execute timerlist, because CST-hardware has no RC_timer key
5c3decd - hardware_caps: introduce caps.has_button_timer
61a116a - channellist/infoviewer: align calculations for "since-time" of current event
17a6df3 CComponentsHeader: avoid possible 'out of range' log message
3baee09 - timerlist: allow RC_timer or RC_program to leave timerlist
a0e1cab - eventlist: use RC_timer or RC_program to execute timerlist; use new timer icon
5752a3b - icons: add icon for timer button
febd3bb - mediaplayer-setup: remove old commented code
bfbb589 infoviewer.cpp: use templates to get reserved width for current/next info
4c2e9bb CBouquetList/CTPSelectHandler: try to fix possible format-overflow errors
853b6e2 CMiscMenue: enlarge menu width
00c87e7 - lcd4l: try to fix strange y-resolution 1088
825e5da CCButtonSelect: unfify bg color parameter order with related base methode
094c3a8 CCButtonSelect: fix order of frame color parameters
905b4f2 Neutrino-3.0.theme: optimize inactive color
672b66f CComponentsForm: add define for default select frame
0cc9465 CUpnpBrowserGui: Ensure clean screen on leaving upnp browser.
b1290fd Osd setup: use unified menu width 50%
65a6d24 - locale: change menu.hint_infobar_radiotext locale
b10e5f9 timerlist: fix double drawing of timer list
047b01c - movieplayer: change logic in updateLcd() function
b30540a - bouqueteditor: allow hiding bouquets with RC_playpause too
e620d9e - movieplayer: allow to display plackback time instead of movietitle on vfd
6e16b28 - yWeb: fix path to ether-wake binary
d2bf7ac enable screenshot for hd51
44c819b - scan-setup: allow three digits for scansettings.sat_TP_pli
e396221 - movieplayer: revert to good ol' vfd-handling; ...
d491602 tuxtxt: fix unused variable warning
8ed1494 tuxtxt: use demux 0
7899eb5 tuxtxt: use blit2FB instead of handmade mem copy
c317bb9 tuxtxt: use framebuffer function for painting boxes
264124e fb_generic: remove unused virtual_fb variable
5415537 remove old framebuffer code files
bd2b665 fb_accel_hd1: fix blit2FB for backbuffer-to-fb case
581effb fb_accel_td: do not use directfb for blitting
5c337db fb_accel_td: fix transp handling in blit2FB
9695798 fb_accel_sti: add verbose error reporting to blit2FB
d6e1ec6 fb_accel_sti: fix blit2FB for source/dest offsets
12a5a29 fb_accel_cs_hd1: blit2FB transp handling
e6e5733 fb_accel_cs_hd1: make blit2FB work with source/dest offsets
4ce4c6f - fb_generic: fix compiler warning
0c757d8 fb_generic: blit2FB: implement "transp" parameter
87b7985 fb_generic: fix blit2FB for big endian processors
a1a0287 - movieplayer: fix RC_ok handling while infoviewer is displayed; ...
10d9e17 infoviewer: fix update of runningRest
ab4762f cc_timer.cpp: don't loop if slot OnTimer is empty
c8f6ff9 yaft: revert to buffer offset calculation for blit2FB
25123fa tuxtxt: fix display of line25 in zoom mode
1a96881 fb_accel_sti: fix render errors
7eed63f 3. try ;) : copy from TangoCash sectiond
8ec4294 - yWeb: activate KEY_BOOKMARKS on hd51 remote controls; thx DdD
cbe7c4f - settings: fix typo (personalize_mplayer_mbrowswer)
ba1468b yaft: fix off-by-one in blit area calculation
9272e27 fb_accel_td: fix blit2FB() for yp != 0 case
dd992f7 cc_frm: fix paintCCItems() y position calculation
a926d2f yaft: reset signal handler after terminal exit
ebb3386 second try to fix segfault on TDT time sync
aa07f92 revert >try to fix segfault on TDT time sync< , this dont work ok on all transponders
9ef2606 - sectionsd: fix compiler warning (‘rc’ may be used uninitialized)
3bff299 supplement to 77ca322a17c11ed647d27f17e386b996d47120d3
82109b2 locales: fix order
5eb5d71 locales: more precise setting for startup volume in audio settings
1b45c65 tuner setup: Visualize current count of selected satellites.
328a0a9 try to fix segfault on TDT time sync
388924a streaminfo2: fix ffmpeg 3.0 API
0919ebe - setting_helpers: replace another ostringstream by simple string
da34a62 - daemon_control: try to fix flagfile detection
80b7354 CComponentsHeader: use internal offset instead OFFSET_INNER_MID
c1e7aa4 Revert "neutrino: fix infobar display with disabled timeout"
9cd7e89 neutrino: fix infobar display with disabled timeout
35890ee infoviewer: force repaint of text fields
5ad063b infoviewer: try to fix infobar font artifacts
f5a80ed update: add TARGET_PREFIX define to backup/install calls
a8bb76e CComponentsHeader: fix possible build error with dangling-else
f3fada8 CScanTs: make left/right borders symmetric
bbbc326 CScanTs: make better use of available space
6897cdb CScanTs::paintLine: fix size calculation for font box
24b0205 fontrender: fix width calculation of bounding box
0048157 fontrenderer: use helper variable for better code readability
9c2a21c fontrenderer: fix inverted logic for "rendering to buffer"
74d27b1 fix overpaint buttons in channellist edit mode
bd3933d fix channellist footer
d35e300 fix no save web channels in bouquets
1ab3d02 - yaft: allow new shell.ttf in yaft-widget too
f874efe yaft: initialize unused variables for valgrind silence ;)
35eaa27 yaft: optimize blit2FB call for partial blit
e3b76a1 yaft: make font rendering more reliable
9d6055a stifb: make blit2FB more flexible wrt blit source
7369640 fontrenderer: adjust width clipping
0de439f yaft: make "CSI ?1c" response linux console compatible
1159cad yaft: optimize for paint == false case
8b6e3c0 yaft: refactor term_init() into init() function
96cf821 yaft: remove unused DCS code artifacts
01f32b3 yaft: remove unnecessary lines_available variable
71ee30d yaft: use neutrino font renderer
73ce32b yaft: improve newline detection
ac5927e yaft: remove support for double-width characters
33dba78 fontrenderer: allow to render into a memory buffer
bc5d6b7 xmlinterface: fix broken to_utf8() algorithm
54f0fe6 - neutrinofonts: add a bit debug output to new SetupShellFont() function
c748264 - fonts: use monospaced tuxtxt font as shell font for shellwindow widget
721300f - neutrinofonts: allow monospaced font for shellwindow widget
e8b2f8a yaft: remove unused files
6be0b18 Revert "yaft/tools/bdf.h fix resource leak"
b1a73e5 yaft: use c++ YaFT_p implementation in yaft_class
d5dcee0 yaft: actually build yaft_priv class
dbc9e68 yaft: convert into c++ class
d5f4ec9 yaft: remove unnecessary cfb struct member
d25f695 yaft: add a second font for low-resolution displays
c3cd2f6 yaft: simplify pointer arithmetics
15824b8 fb_accel_td: don't crash for no reason
d8042a9 - audioplayer: split RC_home/RC_stop handling; ...
7ab983b - channelist: small reworks in numericZap() function; use OFFSET defines
21c5e17 - cc_item_shapes; add ClearBoxRel() function; analogous to PaintBoxRel()
6250ccc - tuxtxt2.conf: align to hardcoded values; align to our current font; install to image
e8baddc - libtuxtxt: some more whitespace cleanups
7e54af7 - libtuxtxt: ports from martii's neutrino-mp ...
88fcd8b - libtuxtxt: move overloaded members directly to the matching functions
6e1f4d2 - libtuxtxt: whitespace cleanup; leading eight spaces => tab
1742453 libtuxtxt: minor clean-up, no code change
6f01e9c - libtuxtxt: cleanup unused lcd code
16fa8e6 Revert "- tuxtxt: align to mp"
4187302 Revert "- tuxtxt: port smooth font rendering from martii's neutrino mp"
ba8532a - neutrino: check for non-existing tuxtxt font
41a31e0 - neutrino: enable caching teletext by default
4f6ba14 - tuxtxt: disable unused defines for alternative fonts
ca5e41e - tuxtxt: port smooth font rendering from martii's neutrino mp
49bd762 src/gui/components/cc_item_picture.h: remove CComponentsPictureScalable
90fff5c src/gui/widget/navibar.cpp/h: fix icon scale
bc510c0 src/gui/components/cc_frm_button.cpp/h: use CComponentsPicture only
1a90bc9 capmt.cpp: debug mp variable
92bb1a2 movieplayer.cpp: move setMoviePlayer() to the right function
2811a92 capmt.cpp: useing sendCaPmt() on unscrambled channels too
af9a9ef - apply tuxtxt font changes to users settings
a3a85e4 yaft/tools/bdf.h fix resource leak
4fd9329 - fonts: cleanup from unused and obsolete fonts
81e8ccc - yWeb: fix typo in 6646aed
94f64ff - controlapi: fix key translation for hd51; small code alignments
6646aed - yWeb: fix key code (KEY_PROGRAM) for hd51 remote controls
f336d4b add revert translate to webif rc
a21fb64 try to fix rc over webif on hd51
5077be0 - zapit/capmt: fix uninitialized ca_map_t no_camap
86cdc12 - framebuffer: better name for getWindowWidth/Height() functions
e900d66 - osd-setup: start browsing for fonts in same dir were active font is located
82bdff5 Revert "channellist: use "classic" width if minitv is unused"
9ed421c - neutrino/miscsettings_menu: fix switching online-services
c2137a6 - eventlist: add small separator line between navibar and footer
980c62d - epgview: add small separator line between navibar and footer
1110206 - neutrinoapi: update getCryptInfoAsString()
e5d8760 neutrinoapi.cpp: fix path to iso tab introduced with 3c859db
2015a63 cc_types: add #include <driver/fb_generic.h>
92adabc data types: use unified type name uint8_t instead u_int8_t
7608924 - locale: remove obsolete AUDIOSelectMenue.volume locale
3b1ee18 - shellwindow: fix position of button; use default color
79c2590 - epgview: fix stupid c/p error; now it's hopefully right
92b6731 - epgview: fix logic for followscreenings- and tmdb-button
bb7f532 - epgview: use OFFSET define for navigation bar
3ae39ce - epgview: take footer height from CComponentsFooter ...
998dce9 - epgview: change and simplify button logic; ...
06a6608 - controlapi: fix control of external plugins (e.g. msgbox or shellexec)
e50b492 armbox: fix hd51 first start rc bug
d403c95 - movieplayer: fix possible endless loop in UpdatePosition() function
7581db2 - user_menu: add item to start timeshift immediately
e7e16d4 - neutrino: add small delay to "save settings" hintbox; ...
f36f51f fix posible memleak
5d686a3 opkg_manager: use CTermWindow()
2ec0b46 test_menu: add CTermWindow() test
bccd547 add working termwindow class
0bf947a configure: enable YaFT widget build
136d6e6 yaft: use TERM=linux, disable unused code
8ffa2ad widget/menue: one more forgotten sys/types.h include
cdbeb9a yaft: add "quiet" mode
92b945e yaft: inline tty_init(), was mostly disabled anyway
1c0fe3b yaft: implement exit code handling, wait for correct child
547692e yaft: prepare for neutrino shellwindow compatibility
e803c1c add int type includes to cc class
6223f10 menue: initialize height variable
47fbfbe reduce dependencies on driver/rcinput.h
6fd601e remove unneeded rcinput.h include in headers
b46ee0c yaft: fix debug logging
587333c yaft: use a bigger font, created from terminus24b
5ba578c yaft: use the neutrino framebuffer functions to blit
d4a5e87 yaft: disable unused dcs functions
af4d9d6 yaft_class: first somehow working version
5c9cc28 yaft.h: fix build with g++, add neutrino stuff
5b3d7b7 yaft/util: disable unused stuff
fd6aa98 yaft/terminal.h: fix compile with g++, remove DRCS stuff
5685b8f yaft/parse: fix compile with g++, disable unused stuff
9a7e106 yaft/util: fix build with g++ and warnings enabled
d409bd2 yaft/fb/common: add neutrino glue, disable unused stuff
6dfe941 yaft/fb/common: remove cmap and wallpaper stuff
10a8cfd yaft neutrinofb.h: add license, remove cmap stuff
a7d382d copy fb/linux.h to fb/neutrinofb.h
0e12b2d add glyph.h
e4eb02f yaft: integrate in neutrino automake system
71a100a import yaft from https://github.com/uobikiemukot/yaft.git commit c455d6a8
04665bf infoviewer: fix copy/paste error clearing wrong field
9875552 cc_item_text: fix "text changed" detection
ac30ba1 neutrino: always clear display when going to standby
f153f3e align bouquet names to delivery system (C/T/E/W)
9ddf19d moving c and t fake positions above 360 degrees
30b47b6 - update_settings: fix update autocheck on/off handling
3a4e207 - update: fix check for installed version; equivalent to d6bc4e2
a4716b5 - icons: restore unoptimized hint icons; there were transparency issues with some optimized icons
42ffc8d CInfoViewer: set names for some items
8cd4654 - infoviewer: remove fixed values from showInfoFile() function
91500b9 - infoviewer: fix offset between event-time and event-name
effdf5b - infoviewer: fix indentation in setInfobarTimeout()
2d01ac2 - infoviewer: rename text_cur_* => text_curr_*
041e086 - infoviewer: rename txt_cur_event_rest => txt_cur_rest
a3913ee - infoviewer: remove LEFT_OFFSET define
d47c8e9 - infoviewer: fix offset between channelnumber and channelname/channellogo
7027cf3 - infoviewer: use OFFSET defines in NI-only code
c2eb139 - infoviewer: use OFFSET defines
62c474e - infoviewer: fix FIXME comment from previous commit
7c166f8 - infoviewer: fix centering in numbox
bf412e4 - remove obsolete code
115862b try to fix 'FE_SET_PROPERTY: Operation not permitted' on cst after add dvb-s2x (supplement)
490b10b try to fix 'FE_SET_PROPERTY: Operation not permitted' on cst after add dvb-s2x
c651393 - update: remove double status calls; seems like a merge error
4f24476 - update: shorten updates lists in menu separators
40b84d1 - flashtool: add posibilty to get localized and non-localized type
b546f6d Revert "Revert "- flashtool: localize getType() function""
3a3f972 - update: show some usefull osd-output while updating hd51
f0292e1 - update: remove obsolete code for flashing tank images (256k)
08ebc3e - locale: improve experimental image warning
72ad3eb - update: use fileType instead of a string to check for experimental image
4817ebb - flashtool: use unused type internal for upcoming nightly builds
df94839 - flashtool: remove wrong todo-comment
a157556 Revert "- flashtool: localize getType() function"
2baedf6 - icon: better lock icon
5949ffd - webtv-setup: use streaming icon in header
47d39e4 - movieplayer: use bookmark icon for bookmark menu
c0b390f - record: use recording icon for recording menu
20b2b67 - icons: larger rec/ts icons for infoviewer
207f6a9 - icons: move mounted/not_mounted to markers; align size to other icons
a8d27ed CComponentsForm: expand debug output to identify current used container
e5e769a - icons: add missing audioplay icon for minitv in channellist
1ee5d86 - icons: add missing question icon
b110ae0 - icons.h: some more re-sorts to get more structure - vol.2
6547f48 - icons.h: some more re-sorts to get more structure
a2a66df - icons: add mute-button icon
db25f2c - icons: rename mute.png => muted.png; ...
208c32f - icons.h: sort movieplayer icons
ebb0fc6 - icons.h: sort infoviewer status icons
9762ac2 - icons: remove unused ca icon
a61defb - icons: add missing longpress icon
c9877dc - icons: remove unused lock_passive icon
488dfd7 - icons: move existing lock icon to header icons
7c02d13 - menu: use new marker icons
4eda8bc - neutrino-menu: use new marker icons
78c2891 - personalize: use new marker icons
5418b57 - network-setup: use new marker icons
39e1927 - channellist: use more new marker icons
2ebb978 - icons: add marker icon for passive locks
d2deb4d - zapit-setup: use new marker icons
c3a68d2 - icon. remove unused epg icon
59b1c42 - bouquetlist: use new marker icons
6bd857d - icons: add new epg marker icon
9427999 - icons: remove unused zap and pip icons
19a8b91 - icons.h: small re-sort
f7da605 - dboxinfo: use new marker icons
0809b16 - hdd_menu: use new marker icons
492e4df - icons: add gray marker icons for timeshift and record
c5851cc - timerlist: use new marker icons
267fa53 - moviebrowser: use new marker icons
b4d2cdb - folowscreenings: use new marker icons
f0465e0 - recording-menu: use new marker icons
65b84b4 - channellist: use new marker icons
0c1000e - icons: add marker icon for pip
33a35ed - eventlist: use new record/timeshift/zap marker icons
bbf60e6 - icons: add marker icons for timeshift and zap events
f49c233 - icons.h: move NEUTRINO_ICON_IMPORTANT to markers; sort markers
b7c43d9 - icons: better names for currently unused NEUTRINO_ICON_MARKER_RECORD
299fdda - icons: rename and sort new marker icons
2648faf - bouqueteditor: use new scrabled- and streaming-marker icons
cc87190 - icons: add marker_scrambled.png and marker_streaming.png
1d50910 - bouqueteditor_channels: use new NEUTRINO_ICON_LOCK_MARKER
4271a35 - icons: remove obsolete hidden.png
df55c4c - icons: add marker_hidden.png to complete marker set in bouqueteditor
14d57ca - icons: replace new icons with material pendants
d76c544 CBEBouquetWidget: use marker icons instead header icons
22d92eb icons: add missing tv and radio markers
336ed7a cc_extra.h: allign method paintImage() and update comments
cf5d138 COsdSetup: ensure reset of channellist modules after any changed osd settings
244cb22 CInfoViewer: reduce paint box calls for record mode
163df1f CInfoViewer: allign vizualized record mode icon
fd55de0 cc: expand cc-type with name
d946947 - movieplayer: remove playlist handling from RC_ok; mpkey_play already handles playlist
9d8bcb1 - neutrino: remove unused __EXPERIMENTAL_CODE__ stuff
f21fe3d - remove obsolete streaminfo includes
15b7901 - user-menu: fix streaminfo include
434d9f6 - info-menu: fix streaminfo include
f2aff12 - libcoolstream-headers: remove obsolete dummy members
9704c79 - movieplayer: revert most code from terrible commit 09ae4c3a5101f7cd7924b35a193b1c829c2cc107
45674b7 - gui/Makefile: compile streaminfo1 instead of streaminfo2 for ARM_HARDWARE
2cd2a85 Revert "- audio_select: copy full code from TangoCash"
4c65ebb - movieplayer: remove unneeded ifdef ENABLE_LUA
58afdfd - movieplayer: minor changes in commented code
5a34b06 - infoicons: avoid extern CInfoIcons; use getInstance() instead of this
be821ed - yWeb: activate RC-sub keys on remote controls
19079a9 - movieplayer: show timeosd when set position
2fd023d - movieplayer: remove unused RC_red handling
e018066 - movieplayer: divide bisectional jumps in half only if direction is changed
a2e4c65 - neutrino: fix usermenu calls for fileplayback_video/audio
e4c4f8d - movieplayer: remove unused "netstream" handling
d844da8 zapit.cpp: disable "tune channel, with stopped playback to not bypass the parental PIN check" on arm hardware
21bc82c - deutsch.locale: fix merge error leftovers
c401847 - movieplayer: remove obsolete playback->SetTeletextPid() call
ca873d6 - movieplayer: remove CRCInput::RC_text handling
b0560ef - movieplayer: add missing std
94c22c7 - movieplayer: remove obsolete static bool running handling
e65e406 - movieplayer: remove unused 3d-code
c19c12b - movieplayer: remove unused ENABLE_GRAPHLCD code
353eba2 - movieplayer: remove unused code
a98f946 dboxinfo: allow to show "neutrino uptime"
2c33e1a move automake's "foreign" switch to the proper place
73c7885 cc_draw: add simple debug facility
b4a3cf1 infoviewer: use all free space for epg title
fe494a6 infoviewer: revert useless big box for running time
120cc5b deutsch.locale: fix typo
8ab511f Channellist: only show lock icon if parental lock is active
207a499 CComponentsHeader: fix text position if icon is removed
2ddd0f7 - update: more logic in some ifdef's
4c6a4ba - update: cleanup and unify debug output
d09f936 - update: fix some defines for ARM_HARDWARE
1b110cd - update: modify LIST_OF_UPDATES_LOCAL_FILENAME define
2caf1f6 - update: remove unused UPDATE_LOCAL_FILENAME define
32a5689 - update: move RELEASE_CYCLE define to configure.ac
1216695 try to fix next file play on AX
0e208db fix play stop on cst after hd51 merge
e092aed CNetworkSetup: cleanup and unify debug output
e53f35d CComponentsWindow: add method to set background image in window classes
3fef935 - user-menu: avoid empty headers in user-menu
97327f0 - filebrowser: add size() and getFilter() members
91ee69f Fileplay: add separat fileplay for audio and video
fb2d6f9 - user-menu: add audio fileplay item
3d5aa59 - neutrino: add more RC_playpause handling
c9e4712 - neutrino: add RC_playpause handling; change some key defaults for ARM_HARDWARE
a4670c7 - rcinput: add RC_playpause key
ebf0719 - zapit/bouquets: don't get auto-epgid from webchannels
