NI-Buildsystem
Re: NI-Buildsystem
mpfr-4.1.0.tar.xz suchen
die ganzen urls haben sich geändert und sind in der aktuellen crosstool-ng auch geändert wurden.
- tannen
- Has thanked: 4 times
- Been thanked: 6 times
Re: NI-Buildsystem
wenn man neu baut müsste die aktuelle crosstool-ng doch auch dabei sein
ich habe jetzt die mpfr-4.1.0.tar.xz auch runter geladen was mir jetzt aber auffällt wenn ich die Dateien in das archiv einfüge sind die bereits vorhanden
ich glaube das bekomme ich dieses mal nicht hin
- tannen
Re: NI-Buildsystem
das geht wieder ein Stück weiter
[INFO ] Performing some trivial sanity checks
[WARN ] Number of open files 1024 may not be sufficient to build the toolchain; increasing to 2048
[INFO ] Build started 20221106.115028
[INFO ] Building environment variables
[INFO ] =================================================================
[INFO ] Retrieving needed toolchain components' tarballs
[INFO ] Retrieving needed toolchain components' tarballs: done in 0.36s (at 00:01)
[INFO ] Extracting and patching toolchain components
[WARN ] linux: using custom location, no patches applied
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Extracting and patching toolchain components'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@376]
[ERROR] >> called from: CT_Extract[scripts/functions@2214]
[ERROR] >> called from: CT_DoExtractPatch[scripts/functions@2304]
[ERROR] >> called from: CT_PackageRun[scripts/functions@2090]
[ERROR] >> called from: CT_ExtractPatch[scripts/functions@2430]
[ERROR] >> called from: do_isl_extract[scripts/build/companion_libs/121-isl.sh@21]
[ERROR] >> called from: do_companion_libs_extract[scripts/build/companion_libs.sh@22]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@666]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> https://crosstool-ng.github.io/docs/known-issues/
[ERROR] >>
[ERROR] >> NOTE: Your configuration includes features marked EXPERIMENTAL.
[ERROR] >> Before submitting a bug report, try to reproduce it without enabling
[ERROR] >> any experimental features. Otherwise, you'll need to debug it
[ERROR] >> and present an explanation why it is a bug in crosstool-NG - or
[ERROR] >> preferably, a fix.
[ERROR] >>
[ERROR] >> If you feel this is a bug in crosstool-NG, report it at:
[ERROR] >> https://github.com/crosstool-ng/crosstool-ng/issues/
[ERROR] >>
[ERROR] >> Make sure your report includes all the information pertinent to this issue.
[ERROR] >> Read the bug reporting guidelines here:
[ERROR] >> http://crosstool-ng.github.io/support/
[ERROR]
[ERROR] (elapsed: 0:14.80)
[00:15] / gmake[1]: *** [ct-ng:261: build] Fehler 2
make: *** [package/crosstool-ng/crosstool-ng.mk:117: crosstool-ng.do_compile] Fehler 2
- tannen
Re: NI-Buildsystem
Danke
aber das es so schlecht baut das war noch nie kann ja wohl nicht am neuesten Linux Mint 21 liegen ich werde noch mal alles löschen und von vorn anfangen
man kann ja nur nach der Anleitung gehen
https://github.com/neutrino-images/ni-buildsystem
Re: NI-Buildsystem
Das liegt an den Quelllinks, die stimmen dann nicht mehr oder sind vorübergehend nicht erreichbar.
- tannen
Re: NI-Buildsystem
hab neu aufgesetzt jetzt sagt er mir das
make toolcheck
Warning: required tool python missing.
make: *** [make/buildsystem-prerequisites.mk:38: find-python] Fehler 1
Re: NI-Buildsystem
Es liegt nicht an LinuxMint 21 benutze ich hier selber.
Es liegt an der crosstool-ng Version die im NI BS hinterlegt ist.
Version ist vom 08 May 2022 in der Zeit ändern sich auch schon einmal URL`s
- tannen
Re: NI-Buildsystem
Danke
also heißt es warten bis das mal geändert wird
- tannen
Re: NI-Buildsystem
mh...
sudo apt-get install python
[sudo] Passwort für tannen:
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Paket python ist nicht verfügbar, wird aber von einem anderen Paket
referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
wurde oder nur aus einer anderen Quelle verfügbar ist.
Doch die folgenden Pakete ersetzen es:
2to3 python2-minimal:i386 python2:i386 python2-minimal python2 dh-python
python-is-python3
E: Für Paket »python« existiert kein Installationskandidat.
Re: NI-Buildsystem
am Python liegt es nicht, die abfrage TOOLCHECK += find-python bezieht sich auf pyhton2 gibt es in den neuen Versionen nicht mehr,
daher sagt er dir ja auch das python3 installiert ist, daher ist diese Ausgabe auch zu vernachlässigen.
möchtest du besser schlafen füge eine 3 bei der Zeile im BS ein TOOLCHECK += find-python3 und dann wirst du sehen bekommst du, die Meldung nicht mehr.
- tannen
Re: NI-Buildsystem
ja das ist mit dem Eintrag ist weg
aber Image bauen weiter nicht möglich Schade...tannen@tannen-PC:~/ni-buildsystem$ make toolcheck
All required tools seem to be installed.
- tannen
Re: NI-Buildsystem
obwohl jetzt alles im archiv vorhanden ist geht es wieder von vorne los da stimmt doch mit dem NI-BS etwas nicht
[INFO ] Build started 20221106.140120
[ERROR] zlib: download failed
Re: NI-Buildsystem
@tannen
habe gerade mal selbst NI-BS unter mint 21 gebaut, das einzige was dem crosstool dabei fehlt ist zlib.
habe dieses in den archives Ordner eingefügt, Rest wurde von selbst geladen und hat auch bis zum Schluss durch gebaut.
muss jetzt mal fragen baust du mit real Linux oder in einer virtuellen Umgebung ?
- tannen
Re: NI-Buildsystem
ich baue in einer echten Umgebung hatte noch nie solche Probleme nur leider ist mein alter PC defekt und die Platte läuft nicht im neuen da hätte ich das alte BS gehabt so muss ich neu aufsetzen.
Re: NI-Buildsystem
baue hier auch in echter Umgebung.
das ist der Fehler den bei make init dann bekomme weil der link zu lua im NI-BS nicht mehr aktuell ist.
Start-up build host-lua
Clean-up host-lua
Resolving dependencies for host-lua
Downloading host-lua
--2022-11-06 15:23:10-- https://www.lua.org/lua-5.2.4.tar.gz
Auflösen des Hostnamens www.lua.org (www.lua.org) … 2a01:4f8:10a:2, 88.99.213.221
Verbindungsaufbau zu www.lua.org (www.lua.org)|2a01:4f8:10a:2|:443 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 404 Not Found
2022-11-06 15:23:10 FEHLER 404: Not Found.
make: *** [package/lua/lua.mk:57: host-lua] Fehler 8
- tannen
Re: NI-Buildsystem
so das mit dem zlib-1.2.12.tar.xz hat mir keine Ruhe gelassen
ich habe jetzt beim bauen den Ordner Download betrachtet da hat sich das BS die zlib vom archives geholt und im Downoad Ordner umbenannt auf zlib-1.2.13.tar.xz
das habe ich noch nie erlebt
ich habe jetzt händig die zlib-1.2.12.tar.xz in den Download Ordner gepackt und jetzt baut es weiter mal schauen wie weit ich komme
- tannen
Re: NI-Buildsystem
host-lua musste ich auch nachladen in den Download Ordner
anschließend DoneStart-up build host-lua
Clean-up host-lua
--2022-11-06 16:31:02-- https://www.lua.org/lua-5.2.4.tar.gz
Auflösen des Hostnamens www.lua.org (www.lua.org) … 88.99.213.221, 2a01:4f8:10a:2
Verbindungsaufbau zu www.lua.org (www.lua.org)|88.99.213.221|:443 … verbunden.
2022-11-06 16:31:03 FEHLER 404: Not Found.
Bootstrapped for Armbox VU+ Zero 4K (vuzero4k)
