Wise Registry Cleaner Pro 10.2.1
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Wise Registry Cleaner Pro 10.2.1
NB: Lifetime license with no upgrades.
Wise Registry Cleaner is one of the safest Registry cleaning tools available in the market today. Its scanning engine is thorough, safe and fast.
It is so easy to use, even the least experienced user can easily repair registry with this tool. It scans the Windows registry and finds incorrect or obsolete information in the registry. By fixing the obsolete information in Windows registry, your system will can work better and more quickly, after Wise Registry Cleaner analyzes your system for problems, you can individually view each of the problems found and call up a detailed description. If you wish, you can also have all problems corrected automatically, all changes to your system are monitored by Wise Registry Cleaner and can be undone with a few mouse clicks, so you can use Wise Registry Cleaner feel relieved.
Multi-user Cleaning
Fix Registry Problems and Boost Your PC Performance
The Practical Backup/Restore Feature
Scheduled Automatic Registry Cleaning
System Tune-up Optimizes System Settings for Better Performance
Customizable Cleanup Options for Advanced Users
Link
mfG
Trapped
Kein Support per PN/Mail
