Und noch ein serielles Log, wenn die HDD nicht mit Namen gemountet wird, beginnend mit der Taste 5 für den Neustart:
key: 0006 value 1, translate: 0006 -5-
StopAutoRecord: autoshift 0
[neutrino] ExitRun(int 2)
[neutrino] hw_caps->can_shutdown: 1
stopPlayBack: stopping...
stopPlayBack: stopped
[zapit.cpp:StopPlayBack:2452] standby 0 playing 1 forced 0 send_pmt 0
[dvb-sub] paused
[scanepg.cpp:Stop:236] stopping live scan...
2023-09-16 03:32:51.304 [sectionsd] Request of stop scanning (now scanning).
ShowText ' '
ShowText 'Speichere EPG'
[neutrino] Saving EPG to /mnt/autofs/NAS_Stick/EPG...
key: 0006 value 0, translate: 0006 -5-
[sectionsd] Try to open file: /mnt/autofs/NAS_Stick/EPG/index.tmp
2023-09-16 03:32:51.670 [sectionsd] Writing Information to file: /mnt/autofs/NAS_Stick/EPG/index.tmp
2023-09-16 03:32:59.726 [sectionsd] Writing Information finished
ShowText ' '
ShowText ' '
ShowText ' '
[dvb-sub] paused
[HAL: b173c078:demux ] Stop #0: not open!
[HAL: b173c078:demux ] Close #0: not open!
[dvb-sub] stopped
streaming shutdown
streaming shutdown done
timerd shutdown
[timerd] stopping timermanager thread ...
[timerd] Waiting for timermanager thread to terminate ...
[timerd] Timermanager thread terminated
[timerd] shutdown: timeset: 1 timer_minutes 0
timerd shutdown complete
timerd shutdown done
sectionsd shutdown
2023-09-16 03:33:00.803 [sectionsd] stopping...
2023-09-16 03:33:00.803 [sectionsd] eitThread::StopRun: to lock
2023-09-16 03:33:00.803 [sectionsd] eitThread::StopRun: to closefd
2023-09-16 03:33:00.803 [sectionsd] eitThread::StopRun: to unlock
2023-09-16 03:33:00.803 [sectionsd] cnThread::StopRun: to lock
2023-09-16 03:33:00.803 [sectionsd] cnThread::StopRun: to closefd
2023-09-16 03:33:00.803 [sectionsd] cnThread::StopRun: to unlock
2023-09-16 03:33:00.803 [sectionsd] timeThread::StopRun: to lock
2023-09-16 03:33:00.804 [sectionsd] timeThread::StopRun: to closefd
2023-09-16 03:33:00.804 [sectionsd] timeThread::StopRun: to unlock
2023-09-16 03:33:00.804 [sectionsd] freeSatThread::StopRun: to lock
2023-09-16 03:33:00.804 [sectionsd] freeSatThread::StopRun: to closefd
2023-09-16 03:33:00.804 [sectionsd] freeSatThread::StopRun: to unlock
2023-09-16 03:33:00.804 [sectionsd] broadcasting...
2023-09-16 03:33:00.804 [sectionsd] pausing...
2023-09-16 03:33:00.804 [sectionsd] join Housekeeping
2023-09-16 03:33:00.804 [sectionsd] join TOT
2023-09-16 03:33:00.804 [sectionsd] timeThread::Stop: to broadcast
2023-09-16 03:33:00.804 [sectionsd] timeThread::Stop: to join
2023-09-16 03:33:00.804 [sectionsd] timeThread stopped
2023-09-16 03:33:00.804 [sectionsd] timeThread::Stop: to close
2023-09-16 03:33:00.804 [sectionsd] join EIT
2023-09-16 03:33:00.804 [sectionsd] eitThread::Stop: to broadcast
2023-09-16 03:33:00.804 [sectionsd] eitThread::Stop: to join
2023-09-16 03:33:00.804 [sectionsd] eitThread stopped
2023-09-16 03:33:00.805 [sectionsd] eitThread::Stop: to close
2023-09-16 03:33:00.805 [sectionsd] join CN
2023-09-16 03:33:00.805 [sectionsd] cnThread::Stop: to broadcast
2023-09-16 03:33:00.805 [sectionsd] cnThread::Stop: to join
2023-09-16 03:33:00.805 [sectionsd] cnThread: stop eit update filter (active)
[HAL: 005e6330:demux ] Close #0: not open!
2023-09-16 03:33:00.805 [sectionsd] cnThread stopped
2023-09-16 03:33:00.805 [sectionsd] cnThread::Stop: to close
2023-09-16 03:33:00.805 [sectionsd] join FSEIT
2023-09-16 03:33:00.805 [sectionsd] freeSatThread::Stop: to broadcast
2023-09-16 03:33:00.805 [sectionsd] freeSatThread::Stop: to join
2023-09-16 03:33:00.805 [sectionsd] freeSatThread stopped
2023-09-16 03:33:00.805 [sectionsd] freeSatThread::Stop: to close
2023-09-16 03:33:00.805 [sectionsd] stopped
sectionsd shutdown done
zapit shutdown
[HAL: 009dc6f0:play  ] ~cPlayback
[HAL: 009dc6f0:play  ] RequestAbort
[zapit] saving channel, apid 203 sub pid 0 mode 0 volume 30
[ConfigFile] saving /var/tuxbox/config/zapit/zapit.conf
[zapit.cpp:StopPlayBack:2452] standby 0 playing 0 forced 0 send_pmt 1
[capmt.cpp:SetMode:324] channel b3e003f90001ef75 [ProSieben HD] mode 0 STOP src 0 mask 1 -> 0 update 0 rmode 0 mp 0
[ca_ci] -> SendCAPMT
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 1
Mode: 0
Enabled: STOP
[ca_ci] -> StopLiveCI
[femanager.cpp:saveSettings:302] fe0
[femanager.cpp:saveSettings:302] fe1
[femanager.cpp:saveSettings:302] fe2
[ConfigFile] saving /var/tuxbox/config/zapit/frontend.conf
[zapit.cpp:run:2889] shutdown started
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to TV (0x03>>0x00) 'standby' ([0x36])
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to TV (0x03>>0x00) 'give device power status' ([0x8F])
[HAL: 005e7fa8:init  ] [CEC] received message TV to all (0x00>>0x0F) 'vendor command with id' ([0xA0][0x00][0x80][0x45][0x20][0x01][0x10])
[HAL: 005e7fa8:init  ] [CEC] decoded message 'vendor command with id' (Panasonic)
[HAL: 005e7fa8:init  ] [CEC] received message TV to Tuner 1 (0x00>>0x03) 'report power status' ([0x90][0x01])
[HAL: 005e7fa8:init  ] [CEC] TV reporting state off (1)
[zapit.cpp:run:2926] demuxes/decoders deleted
[frontend.cpp:Close:365] [fe0/0] close frontend fd 9
[frontend.cpp:Close:365] [fe0/1] close frontend fd 10
[frontend.cpp:Close:365] [fe0/2] close frontend fd 11
[zapit.cpp:run:2936] frontend(s) deleted
[zapit.cpp:run:2938] stopping CA
[ca_ci] -> Stop
[ca_ci] -> ~cCA
[zapit.cpp:run:2942] shutdown complete
zapit shutdown done
ShowText ' '
[ca_ci] -> GetNumberCISlots
entering off state
timer_minutes: 0
[fb_accel_arm] run end
[HAL: 00000000:init  ] hal_api_exit, initialized = 1
[neutrino] This is the end. Exiting with code 2
INIT:
INIT: Sending processes configured via /etc/inittab the TERM signal
Sep 16 03:33:03 E4HD user.info K01camd[6002]: stop camd_datefix
Sep 16 03:33:03 E4HD user.info K01camd[6002]: stop oscam
sh: you need to specify whom to kill
[K20rcu_switcher] Usage: /etc/rc6.d/K20rcu_switcher {start}
Sep 16 03:33:08 E4HD user.info K25autofs[6095]: stopping
stopping nmbd ...done
stopping smbd ...done
Sep 16 03:33:08 E4HD user.info K98fstab[6166]: unmount all netfs stuff from /etc/mtab
Sep 16 03:33:08 E4HD user.info K98network[6171]: Deconfiguring network ...
Sep 16 03:33:08 E4HD user.info rcK[6191]: start
Sep 16 03:33:08 E4HD user.info rcK[6191]: done
[ 1928.772161] reboot: Restarting system
CPU 01
BCM74390012
PRID07252112
v1.7
RR:00000200
BFW
SEC
seclib-1.5
BBL v1.0.1
AVS init...
spare0/rmon_hz=017b736f
spare1/rmon_vt=017b7370
AVS init OK
AVS load:select_image: addr_offset: 00051000 part_offset: 00000000 bootStatus: 2a252b25
AVS load_code offset =00051000
AVS: OTP Decrypt 0x00000000, OTP Verify AVS 0x00000000
LOADED
single board
select_image: addr_offset: 00055000 part_offset: 00000000 bootStatus: 3d2b2525
MemsysFW: OTP Decrypt 0x00000000, OTP Secure Boot 0x00000000
SHMOO 01020000 BLD:9695 HW:hpf0_b1p6 V:1.2.0.0
MCB: FIX
AVS start:NO
DDR0: *@ ffe0ba98 <= ffe0ba98 MEMSYS-0 @ f1100000 OK
DDR1: *@ ffe0ba98 <= ffe0ba98 MEMSYS-1 @ f1180000 OK
Sdram Scramble OTP = 0x00000001
Sdram Scramble OK
select_image: addr_offset: 00020000 part_offset: 00000000 bootStatus: 1b25252b
BFW load mode OTP = 0x0000000f
bfw_hash_locked = 0x00000000
BFW key3 OK, BFW load OK
BFW v2.1.0
COPY CODE... DONE
OTP SSBL Encrypt 0x00000000
OTP Sec Boot 0x00000000
OTP read MichEn 0x00000000
MICH: disable success
SSBL
no v092_to_v095 conversion is performed
PINMUX
CACHE FLUSH OK
MMU ON
CACHE FLUSH OK
_fbss  0704d000
_ebss  0704ea68
_end   0704ea88
HEAP @ 07100000
STACK @ 09200000
ARCH: CONFIG OK
CLR BSS 0704d000 to 0704ea68 OK
CLR SRAM  OK
CACHE FLUSH OK
CPU CLKSET OK
GO!
  ,'/___, BOLT v1.07 v1.07-r36 e4hd
.'__  ,'  (2018-01-27 )
   /,'    Copyright (C) 2018 Broadcom Corporation
Board: BCM97252SSV
SYS_CTRL: product=72521, family=7439b2, strap=000000b2,
otp @ 0xf0404030 = 0x822000e0: en_cr(0x00000060) en_testport(0x00000080) macrovision_disable(0x02000000) moca_disable(0x80000000) rv9_disable(0x00200000)
otp @ 0xf0404034 = 0x00000021: moca2_disable(0x00000001) rfm_disable(0x00000020)
CPU: 2x A15, 1719 MHz
SCB: 432 MHz
DDR0 @ 1061MHz, DDR1 @ 1061MHz
CS0: SFDP SPI, 32MB, 64kB blocks, 256B pages
CS1: NAND: unrecognized ID: 0x7effff 0xffffffff
RTS0: 0x1101004, 256 clients, ok
RTS1: 0x1181004, 256 clients, ok
BOX MODE: 2
AVS: park check
AVS: temperature monitoring enabled
AVS: V=0.969V, T=+62.809C (no AVS FW)
USB otp=00000040
board selection update!
board was ?, now a (flags:0xffe00000)
Executing STARTUP...
Loader:zimg Filesys:raw Dev:emmcflash0.kernel3 File:(null) Options:brcm_cma=504M@264M brcm_cma=192M@768M brcm_cma=1024M@2048M root=/dev/mmcblk0p7 rw rootwait e4hdultra_4.boxmode=5
Reading 4834696 bytes from zImage...........
Starting program at 0x8000 (DTB @ 0x761c000)
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.10.12 (neutrino-images@nisrv) (gcc version 12.2.0 (crosstool-NG 1.25.0.166_9433647_dirty) ) #1 SMP Sat Sep 9 06:31:08 CEST 2023
[    0.000000] CPU: ARMv7 Processor [420f00f3] revision 3 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt:Machine model: BCM97252SSV
[    0.000000] cma_driver: __cma_rsv_setup: too many regions, ignoring extras
[    0.000000] Malformed early option 'brcm_cma'
[    0.000000] cma: Reserved 504 MiB at 0x0000000010800000
[    0.000000] cma: Reserved 192 MiB at 0x0000000030000000
[    0.000000] cma: Reserved 1024 MiB at 0x0000000080000000
[    0.000000] cma: Failed to reserve 504 MiB
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] percpu: Embedded 14 pages/cpu @cebbd000 s26764 r8192 d22388 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 522560
[    0.000000] Kernel command line: brcm_cma=504M@264M brcm_cma=192M@768M brcm_cma=1024M@2048M root=/dev/mmcblk0p7 rw rootwait e4hdultra_4.boxmode=5 brcm_cma=504M@264M brcm_cma=192M@768M brcm_cma=1024M@2048M console=ttyS0,115200 consoleblank=0 vt.global_cursor_default=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 305204K/2097152K available (7197K kernel code, 363K rwdata, 1784K rodata, 340K init, 219K bss, 30668K reserved, 1761280K cma-reserved, 65536K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc070f908   (7199 kB)
[    0.000000]       .init : 0xc08fb000 - 0xc0950000   ( 340 kB)
[    0.000000]       .data : 0xc0950000 - 0xc09aadb8   ( 364 kB)
[    0.000000]        .bss : 0xc09ac000 - 0xc09e2f2c   ( 220 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] Build-time adjustment of leaf fanout to 32.
[    0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf0805000, parent irq: 16)
[    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf0807000, parent irq: 17)
[    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf0809640, parent irq: 18)
[    0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xf080b200, parent irq: 19)
[    0.000000] irq_bcm7120_l2: registered BCM7120 L2 intc (mem: 0xfc40a700, parent IRQ(s): 2)
[    0.000000] irq_bcm7120_l2: registered BCM7120 L2 intc (mem: 0xf080d380, parent IRQ(s): 3)
[    0.000000] brcmstb: biuctrl: MCP: Write pairing already disabled
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 27.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x63a1e71a3, max_idle_ns: 440795203123 ns
[    0.000004] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
[    0.000012] Switching to timer-based delay loop, resolution 37ns
[    0.000276] Console: colour dummy device 80x30
[    0.000297] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
[    0.000305] pid_max: default: 32768 minimum: 301
[    0.000409] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000416] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000864] CPU: Testing write buffer coherency: ok
[    0.001120] CPU0: update cpu_capacity 1024
[    0.001126] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001340] Setting up static identity map for 0x8440 - 0x8498
[    0.003327] smp: Bringing up secondary CPUs ...
[    0.004050] CPU1: update cpu_capacity 1024
[    0.004053] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.004111] smp: Brought up 1 node, 2 CPUs
[    0.004121] SMP: Total of 2 processors activated (108.00 BogoMIPS).
[    0.004126] CPU: All CPU(s) started in SVC mode.
[    0.004526] devtmpfs: initialized
[    0.010570] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
[    0.010766] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.010780] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.046509] NET: Registered protocol family 16
[    0.046935] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.051599] cpuidle: using governor ladder
[    0.056608] cpuidle: using governor menu
[    0.064790] No ATAGs?
[    0.064861] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.064869] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.074564] SCSI subsystem initialized
[    0.074816] usbcore: registered new interface driver usbfs
[    0.074850] usbcore: registered new interface driver hub
[    0.074879] usbcore: registered new device driver usb
[    0.074918] Linux cec interface: v0.10
[    0.074948] Linux video capture interface: v2.00
[    0.074989] pps_core: LinuxPPS API ver. 1 registered
[    0.074993] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.075004] PTP clock support registered
[    0.075303] Advanced Linux Sound Architecture Driver Initialized.
[    0.075723] clocksource: Switched to clocksource arch_sys_counter
[    0.075923] FS-Cache: Loaded
[    0.080480] NET: Registered protocol family 2
[    0.080851] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.080891] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.080965] TCP: Hash tables configured (established 8192 bind 8192)
[    0.081051] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.081077] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.081183] NET: Registered protocol family 1
[    0.081464] RPC: Registered named UNIX socket transport module.
[    0.081470] RPC: Registered udp transport module.
[    0.081473] RPC: Registered tcp transport module.
[    0.081476] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.081825] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.082838] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.083331] NFS: Registering the id_resolver key type
[    0.083353] Key type id_resolver registered
[    0.083357] Key type id_legacy registered
[    0.083368] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.083372] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.083664] fuse init (API version 7.26)
[    0.085650] bounce: pool size: 64 pages
[    0.085687] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.085693] io scheduler noop registered
[    0.085697] io scheduler deadline registered
[    0.085740] io scheduler cfq registered (default)
[    0.086000] brcm-gisb-arb f0400000.gisb-arb: registered mem: f09fd000, irqs: 47, 48
[    0.086268] brcm-sata-phy f0458100.sata-phy: registered 1 port(s)
[    0.086562] brcm-cma brcm-cma.0: Initialized Broadcom CMA root device
[    0.087165] brcm-cma brcm-cma.0: Added CMA device @ PA=0x10800000 LEN=0x1f800000
[    0.087654] brcm-cma brcm-cma.1: Added CMA device @ PA=0x30000000 LEN=0xc000000
[    0.088193] brcm-cma brcm-cma.2: Added CMA device @ PA=0x80000000 LEN=0x40000000
[    0.114843] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.116141] console [ttyS0] disabled
[    0.116178] f040a900.serial: ttyS0 at MMIO 0xf040a900 (irq = 34, base_baud = 5062500) is a 16550A
[    0.844888] console [ttyS0] enabled
[    0.848887] f040a940.serial: ttyS1 at MMIO 0xf040a940 (irq = 35, base_baud = 5062500) is a 16550A
[    0.858183] f040a980.serial: ttyS2 at MMIO 0xf040a980 (irq = 36, base_baud = 5062500) is a 16550A
[    0.873813] brd: module loaded
[    0.880367] loop: module loaded
[    0.884245] OF: /rdb/sata@f045a000/sata-port@0: could not get #phy-cells for /rdb/sata-phy@f0458100
[    0.893412] brcm-ahci f045a000.sata: masking port_map 0x3 -> 0x1
[    0.899486] brcm-ahci f045a000.sata: SSS flag set, parallel bus scan disabled
[    0.916731] brcm-ahci f045a000.sata: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x1 impl platform mode
[    0.925718] brcm-ahci f045a000.sata: flags: 64bit ncq sntf stag pm clo pmp slum part
[    0.934789] scsi host0: brcm-ahci
[    0.938370] scsi host1: brcm-ahci
[    0.941840] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 44
[    0.949776] ata2: DUMMY
[    0.952239] brcm-ahci f045a000.sata: Broadcom AHCI SATA3 registered
[    0.959202] libphy: Fixed MDIO Bus: probed
[    0.963581] bcmgenet f0b00000.ethernet: GENET 4.5 EPHY: 0x1001
[    0.981735] libphy: bcmgenet MII bus: probed
[    1.008694] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.014552] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.038445] ehci-brcm: EHCI BRCM driver
[    1.042401] ehci-brcm f0470300.ehci: EHCI Host Controller
[    1.047832] ehci-brcm f0470300.ehci: new USB bus registered, assigned bus number 1
[    1.065532] ehci-brcm f0470300.ehci: irq 147, io mem 0xf0470300
[    1.067106] ata1: SATA link down (SStatus 0 SControl 300)
[    1.083731] ehci-brcm f0470300.ehci: USB 2.0 started, EHCI 1.00
[    1.090178] hub 1-0:1.0: USB hub found
[    1.093987] hub 1-0:1.0: 1 port detected
[    1.098202] ehci-brcm f0470500.ehci: EHCI Host Controller
[    1.103633] ehci-brcm f0470500.ehci: new USB bus registered, assigned bus number 2
[    1.121317] ehci-brcm f0470500.ehci: irq 148, io mem 0xf0470500
[    1.133730] ehci-brcm f0470500.ehci: USB 2.0 started, EHCI 1.00
[    1.140065] hub 2-0:1.0: USB hub found
[    1.143853] hub 2-0:1.0: 1 port detected
[    1.147981] ohci-brcm: OHCI BRCM driver
[    1.151963] ohci-brcm f0470400.ohci: BRCM OHCI controller
[    1.157392] ohci-brcm f0470400.ohci: new USB bus registered, assigned bus number 3
[    1.165036] ohci-brcm f0470400.ohci: irq 149, io mem 0xf0470400
[    1.227089] hub 3-0:1.0: USB hub found
[    1.230877] hub 3-0:1.0: 1 port detected
[    1.235025] ohci-brcm f0470600.ohci: BRCM OHCI controller
[    1.240455] ohci-brcm f0470600.ohci: new USB bus registered, assigned bus number 4
[    1.248103] ohci-brcm f0470600.ohci: irq 150, io mem 0xf0470600
[    1.310145] hub 4-0:1.0: USB hub found
[    1.313932] hub 4-0:1.0: 1 port detected
[    1.318087] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.324645] ehci-pci: EHCI PCI platform driver
[    1.329153] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.335358] ohci-pci: OHCI PCI platform driver
[    1.340120] xhci-hcd f0471000.xhci: xHCI Host Controller
[    1.345463] xhci-hcd f0471000.xhci: new USB bus registered, assigned bus number 5
[    1.353158] xhci-hcd f0471000.xhci: hcc params 0x0250f17d hci version 0x100 quirks 0x00010010
[    1.361737] xhci-hcd f0471000.xhci: irq 151, io mem 0xf0471000
[    1.368318] hub 5-0:1.0: USB hub found
[    1.372116] hub 5-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    1.379379] xhci-hcd f0471000.xhci: xHCI Host Controller
[    1.384719] xhci-hcd f0471000.xhci: new USB bus registered, assigned bus number 6
[    1.392268] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.400731] hub 6-0:1.0: USB hub found
[    1.404506] hub 6-0:1.0: 2 ports detected
[    1.408817] usbcore: registered new interface driver uas
[    1.414205] usbcore: registered new interface driver usb-storage
[    1.420660] mousedev: PS/2 mouse device common for all mice
[    1.426472] i2c /dev entries driver
[    1.430197] IR NEC protocol handler initialized
[    1.434748] IR RC5(x/sz) protocol handler initialized
[    1.439813] IR RC6 protocol handler initialized
[    1.444356] IR JVC protocol handler initialized
[    1.448899] IR Sony protocol handler initialized
[    1.453528] IR SANYO protocol handler initialized
[    1.458243] IR Sharp protocol handler initialized
[    1.462959] IR MCE Keyboard/mouse protocol handler initialized
[    1.468806] IR XMP protocol handler initialized
[    1.473353] smssdio: Siano SMS1xxx SDIO driver
[    1.477809] smssdio: Copyright Pierre Ossman
[    1.482393] sdhci: Secure Digital Host Controller Interface driver
[    1.488592] sdhci: Copyright(c) Pierre Ossman
[    1.492962] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.500937] usb 2-1: new high-speed USB device number 2 using ehci-brcm
[    1.522599] hub 2-1:1.0: USB hub found
[    1.526526] hub 2-1:1.0: 4 ports detected
[    1.538737] mmc0: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
[    1.546303] hidraw: raw HID events driver (C) Jiri Kosina
[    1.551865] usbcore: registered new interface driver usbhid
[    1.557451] usbhid: USB HID core driver
[    1.563876] NET: Registered protocol family 17
[    1.568403] Key type dns_resolver registered
[    1.572754] ThumbEE CPU extension supported.
[    1.577041] Registering SWP/SWPB emulation handler
[    1.589206] ALSA device list:
[    1.592220]   No soundcards found.
[    1.596252] Waiting for root device /dev/mmcblk0p7...
[    1.671171] mmc0: new high speed MMC card at address 0001
[    1.676985] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
[    1.681666] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
[    1.687732] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
[    1.693796] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
[    1.702794]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    1.712261] EXT4-fs (mmcblk0p7): couldn't mount as ext3 due to feature incompatibilities
[    1.722810] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd
[    1.742205] usb 6-1: USB controller f0471000.xhci does not support streams, which are required by the UAS driver.
[    1.752502] usb 6-1: Please try an other USB controller if you wish to use UAS.
[    1.759869] usb 6-1: USB controller f0471000.xhci does not support streams, which are required by the UAS driver.
[    1.770159] usb 6-1: Please try an other USB controller if you wish to use UAS.
[    1.777487] usb-storage 6-1:1.0: USB Mass Storage device detected
[    1.784778] scsi host2: usb-storage 6-1:1.0
[    1.800113] random: fast init done
[    1.807084] EXT4-fs (mmcblk0p7): recovery complete
[    1.812347] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.820504] VFS: Mounted root (ext4 filesystem) on device 179:7.
[    1.827368] devtmpfs: mounted
[    1.830766] Freeing unused kernel memory: 340K
[    1.835224] This architecture does not have kernel memory protection.
[    1.835738] usb 2-1.2: new full-speed USB device number 3 using ehci-brcm
INIT: version  booting
Jan 01 01:00:01 (none) user.info rcS[116]: start
Jan 01 01:00:01 (none) user.info rcS[116]: creating and mounting system directories ...
mount: mounting devtmpfs on /dev failed: Device or resource busy
Sun Jan  1 00:00:00 CET 2023
* Applying /etc/sysctl.conf ...
/lib/mdev/fs/mdev-mount: line 89: can't create /proc/stb/lcd/symbol_hdd: nonexistent directory
Jan 01 00:00:15 E4HD user.info network[1200]: Configuring network ...
OSD-RES: 220 x 176
INIT: Entering runlevel: 3
Jan 01 00:00:16 E4HD user.info S01fstab[1323]: mount all local stuff from /etc/fstab
Jan 01 00:00:16 E4HD user.info S01fstab[1323]: mount all netfs stuff from /var/etc/fstab
Jan 01 00:00:17 E4HD user.info S75autofs[1354]: starting
open_fopen_r:211: failed to open file: No such file or directory
starting smbd ...done
starting nmbd ...done
Jan 01 00:00:28 E4HD user.info S98camd[1577]: start camd_datefix
Jan 01 00:00:28 E4HD user.info camd_datefix[1580]: manipulating date ...
Sep 16 03:33:00 E4HD user.info camd_datefix[1580]: done (202309160333)
Sep 16 03:33:00 E4HD user.info S98camd[1577]: start oscam
[HAL: 00000000:init  ] [CEC] new instance created
[neutrino] create CA Instance
[ca_ci] -> GetInstance
[ca_ci] -> cCA 1
set input0 to tuner A
set input1 to tuner B
set input2 to tuner C
set input3 to tuner D
[HAL: hal_debug] libstb-hal debug options can be set by exporting HAL_DEBUG.
The following values (or bitwise OR combinations) are valid:
component: audio   0x01
component: video   0x02
component: demux   0x04
component: play    0x08
component: power   0x10
component: init    0x20
component: ca      0x40
component: record  0x80
all components:    0xff
[HAL: 00000000:init  ] hal_api_init begin, initialized=0, debug=0x00
[HAL: beaf0c5c:power ] SetCpuFreq(0) => set standby = false
[HAL: 00000000:init  ] hal_api_init end
[CA] Slot0: Waiting for zapit
[neutrino] armbox framebuffer Instance created
[fb_generic] [bcmfb] framebuffer 24300k video mem
[fb_accel_arm] run start
[fb_accel_arm] SetMode: 32bits, red 8:16 green 8:8 blue 8:0 transp 8:24
[fb_accel_arm] 1920x1080x32 line length 7680. using bcmfb graphics accelerator.
[HAL: 00000000:init  ] hal_api_init begin, initialized=1, debug=0x00
[neutrino] recording dir: /media/bar2tb/movies
[neutrino] timeshift dir: /media/bar2tb/movies/.timeshift
[CWebChannelsSetup] loading: /var/tuxbox/webtv/skyicam.tv
[CWebChannelsSetup] skipping: /var/tuxbox/webtv/webtv_usr.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webtv/plutotv.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webtv/plutotv_us.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webtv/rakutentv.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webtv/yt_live.xml
[CWebChannelsSetup] skipping: /var/tuxbox/webradio/webradio_usr.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webradio/80s80s.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webradio/90s90s.xml
[CWebChannelsSetup] loading: /usr/share/tuxbox/neutrino/webradio/stompfm.xml
[neutrino] [CNeutrinoFonts] [SetupNeutrinoFonts - 173] font file: /usr/share/fonts/neutrino.ttf
[neutrino] [CNeutrinoFonts] [SetupNeutrinoFonts - 195] standard font family: Roboto
[neutrino] [CNeutrinoFonts] [SetupDynamicFonts - 155] dynamic font family: Roboto
[neutrino] [CNeutrinoFonts] [SetupIconFont - 297] icon font family: Font Awesome 6 Free (/usr/share/fonts/fa-solid-900.ttf)
ShowText ''
ShowText ' '
ShowText 'NI \o/'
CLCD::setScrollMode scroll_repeats:1
[fe0/0] frontend fd 9 type 0
[fe0/0] add delivery system DVB-S (delivery_system: 5)
[fe0/0] add delivery system DVB-S2 (delivery_system: 6)
[fe0/0] add delivery system DVB-S2X (delivery_system: 6 / Multistream: yes)
[fe0/1] frontend fd 8 type 0
[fe0/1] add delivery system DVB-S (delivery_system: 5)
[fe0/1] add delivery system DVB-S2 (delivery_system: 6)
[fe0/1] add delivery system DVB-S2X (delivery_system: 6 / Multistream: yes)
[femanager.cpp:Init:102] add fe 1
[fe0/2] frontend fd 11 type 0
[fe0/2] add delivery system DVB-S (delivery_system: 5)
[fe0/2] add delivery system DVB-S2 (delivery_system: 6)
[fe0/2] add delivery system DVB-S2X (delivery_system: 6 / Multistream: yes)
[femanager.cpp:Init:102] add fe 2
[frontend.cpp:Open:198] /dev/dvb/adapter0/frontend3: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter1/frontend0: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter1/frontend1: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter1/frontend2: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter1/frontend3: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter2/frontend0: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter2/frontend1: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter2/frontend2: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter2/frontend3: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter3/frontend0: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter3/frontend1: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter3/frontend2: No such file or directory
[frontend.cpp:Open:198] /dev/dvb/adapter3/frontend3: No such file or directory
[femanager.cpp:Init:118] found 3 frontends, 4 demuxes
[HAL: 006cf060:audio ] cAudio::setVolume(30, 30)
[zapit] Loading services, channel size 528 ..
[getservices.cpp:LoadServices:917] Loading satellites...
[getservices.cpp:FindTransponder:623] going to parse dvb-s provider Astra (19.2E)
[zapit] 1712 services loaded (1712)...
[zapit] service loading took: 27 msec
[zapit.cpp:PrepareChannels:1194] LoadServices: success
[bouquets.cpp:readEPGMapping:1451] read /var/tuxbox/config/zapit/epgmap.xml
[bouquets.cpp:parseBouquetsXml:421] reading bouquets from /var/tuxbox/config/zapit/bouquets.xml
[bouquets.cpp:parseBouquetsXml:523] total: 56 bouquets
[bouquets.cpp:loadWebchannels:891] Loading webtv from /var/tuxbox/webtv/webtv_usr.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webtv from /var/tuxbox/webtv/skyicam.tv ...
[bouquets.cpp:loadWebchannels:891] Loading webtv from /usr/share/tuxbox/neutrino/webtv/plutotv.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webtv from /usr/share/tuxbox/neutrino/webtv/plutotv_us.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webtv from /usr/share/tuxbox/neutrino/webtv/rakutentv.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webtv from /usr/share/tuxbox/neutrino/webtv/yt_live.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webradio from /var/tuxbox/webradio/webradio_usr.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webradio from /usr/share/tuxbox/neutrino/webradio/80s80s.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webradio from /usr/share/tuxbox/neutrino/webradio/90s90s.xml ...
[bouquets.cpp:loadWebchannels:891] Loading webradio from /usr/share/tuxbox/neutrino/webradio/stompfm.xml ...
[bouquets.cpp:parseBouquetsXml:421] reading bouquets from /var/tuxbox/config/zapit/ubouquets.xml
[bouquets.cpp:parseBouquetsXml:523] total: 149 bouquets
[zapit] bouquet loading took: 172 msec
[zapit.cpp:Start:2707] channels have been loaded succesfully
[zapit.cpp] diseqc type = 0
[femanager.cpp:loadSettings:225] load config for fe0
[femanager.cpp:loadSettings:225] load config for fe1
[femanager.cpp:loadSettings:225] load config for fe2
[femanager.cpp:linkFrontends:374] linking..
[femanager.cpp:linkFrontends:401] Frontend #1: link to master 0 as LOOP
[femanager.cpp:linkFrontends:415] Frontend #0: is master, with loop: yes, with rotor: no
[frontend.cpp:setDiseqcType:1685] fe0: NO_DISEQC
[femanager.cpp:linkFrontends:418] Frontend #1: is LOOP, master 0
[frontend.cpp:setDiseqcType:1685] fe1: NO_DISEQC
[femanager.cpp:linkFrontends:425] Frontend #2: is independent
[frontend.cpp:setDiseqcType:1685] fe2: NO_DISEQC
[ca_ci] -> SetInitMask param:3
[ca_ci] -> SetTSClock for Slot0 to: normal
[ca_ci] -> Start
[zapit] GetConfig...
[zapit] starting... tid 1692
[zapit] sdt monitor started
[neutrino] [CVideoSettings] [setupVideoSystem - 659], setup video system...
>>>>>[src/gui/osd_helpers.cpp - setVideoSystem:216] before SetVideoSystem:
                var.xres        : 1920, var.yres    : 1080, var.yres_virtual: 2160
                fix.line_length : 7680, fix.smem_len: 24883200 Byte
[HAL: 006d70e8:video ] SetVideoSystem: old: '720p50' new: '2160p50'
[zapit.cpp:ParseCommand:1293] cmd 96 in standby mode
>>>>>[src/gui/osd_helpers.cpp - setVideoSystem:229] after SetVideoSystem:
>>>>>[changeOsdResolution:75] osd mode: OSDMODE_1080 => OSDMODE_1080, automode: true, forceOsdReset: false
[neutrino] [CVideoSettings] [initVideoSettings - 610], init video settings...
[zapit.cpp:ZapIt:533] [zapit] zap to ProSieben HD (b3e003f90001ef75 tp 2cc800c003f90001)
[femanager.cpp:allocateFE:719] pip demux: 1
[zapit.cpp:StopPlayBack:2452] standby 1 playing 0 forced 0 send_pmt 1
[rcinput:checkdev] /dev/input mtime changed
[rcinput:open] opened /dev/input/event3 (fd 20) ev 0x100013
[rcinput:open] opened /dev/input/event2 (fd 18) ev 0x3
[rcinput:open] opened /dev/input/event1 (fd 19) ev 0x100003
[rcinput:open] opened /dev/input/event0 (fd 17) ev 0x100003
[fe0/0] tune to 11464000 DVB-S2 8PSK 2/3 H/L srate 22000000 pli -1 plc 0 plm 1 (tuner 1714000 offset 9750000 timeout 4000)
[frontend.cpp:setFrontend:1546] [fe0/0] tuner pilot 2 (feparams 2) streamid (-1/0/1)
[frontend.cpp:getEvent:807] [fe0/0] ******** FE_HAS_LOCK: freq 1714000
[fe0/0] tuning took: 342 msec (min 342 max 342)
[HAL: b0100838:demux ] _open: setting /dev/dvb/adapter0/demux0 to source 0
[zapit] parsing pmt pid 0x61 (ProSieben HD)
[subtitle] TTXSub: PID=0x0021, lang=deu, page=149
[pmt] found aitpid: 0x205
[zapit] channel found, audio pid 203, subtitle pid 0 mode 0 volume 30
[zapit.cpp:StartPlayBack:2368] standby 1 playing 0 forced 0
[capmt.cpp:SetMode:324] channel b3e003f90001ef75 [ProSieben HD] mode 0 START src 0 mask 0 -> 1 update 0 rmode 0 mp 0
[capmt.cpp:SetMode:353]  socket only
[capmt.cpp:SetMode:488] CI: use CI for [ProSieben HD]
[capmt.cpp:SetMode:499]  (oldmask != newmask) || force_update)
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 1
CALEN: 485
Scrambled: 1
Mode: 0
Enabled: START
[ca_ci] -> FindFreeSlot
No free ci-slot
Service Caids: 098c 098d 09c4 1830 1842 1843 1860 186a 186d 4af4 4b64
[pmt] set update filter, sid 0xef75 pid 0x61 version 1
[ait] trying to parse AIT
[zapit.cpp:leaveStandby:2524] standby 1 recording 0
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 1
Mode: 0
Enabled: STOP
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 1
CALEN: 485
Scrambled: 1
Mode: 0
Enabled: START
No free ci-slot
[neutrino CEC Settings] setCECSettings init CEC settings...
[HAL: 005e7fa8:init  ] [CEC] switch on SetCECMode
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to TV (0x03>>0x00) 'get cec version' ([0x9F])
CAit::Read: pid 205 found
[ait] detected AppID: 2, AppName: ProSieben, Url: http://hbbtv.redbutton.de/service/redbutton.php?brand=p7de profilecode: 0 orgid: 96 sectionLength: 267 profileVersion 65793
[scan] AIT finished.
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to TV (0x03>>0x00) 'image view on' ([0x04])
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to all (0x03>>0x0F) 'active source' ([0x82][0x10][0x00])
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to all (0x03>>0x0F) 'set osd name' ([0x47][0x6E][0x65][0x75][0x74][0x72][0x69][0x6E][0x6F])
[sdt monitor] wakeup...
[HAL: 005e7fa8:init  ] [CEC] send message Tuner 1 to Audio System (0x03>>0x05) 'give audio status' ([0x71])
[HAL: 005e7fa8:init  ] [CEC] received message TV to Tuner 1 (0x00>>0x03) 'report power status' ([0x90][0x02])
[HAL: 005e7fa8:init  ] [CEC] TV reporting state on (2)
[HAL: 005e7fa8:init  ] [CEC] received message TV to all (0x00>>0x0F) 'vendor command with id' ([0xA0][0x00][0x80][0x45][0x20][0x00][0x00])
CStreamManager::Listen: on 31339, fd 36
[yhttpd] Webserver nhttpd/3.4.1 (yhttpd_core/1.3.2) tid 1865
[HAL: b173cb00:demux ] Stop #0: not open!
timerd startup, tid 1862
Starting STREAM thread keeper, tid 1866
2023-09-16 03:33:08.276 [sectionsd] start
2023-09-16 03:33:08.276 [sectionsd] Caching: 14 days, 360 hours Extended Text, max 150000 events, Events are old 1 hours after end time
2023-09-16 03:33:08.276 [sectionsd] NTP: enabled, command /usr/sbin/ntpdate 0.de.pool.ntp.org
2023-09-16 03:33:08.277 [sectionsd] starting
2023-09-16 03:33:08.277 [sectionsd] SIevent size: 92
2023-09-16 03:33:08.277 [sectionsd] ====> USING SLOW ADDEVENT. export 'NO_SLOW_ADDEVENT=1' to avoid <===
2023-09-16 03:33:08.281 [sectionsd] timeThread::run:: starting, pid 1639 (2869908480)
2023-09-16 03:33:08.287 [sectionsd] eitThread::run:: starting, pid 1639 (2861515776)
2023-09-16 03:33:08.288 [sectionsd] cnThread::run:: starting, pid 1639 (2853123072)
2023-09-16 03:33:08.288 [sectionsd] freeSatThread::run:: starting, pid 1639 (2844730368)
CInfoIcons::Init() reports 5 entries
CI: CAM not found
CI: CAM not found
[neutrino] menue setup
[neutrino] init menus...
[neutrino] mediaplayer menu instance created
[neutrino] [CNetworkSetup][getInstance - 90],  Instance created
[neutrino] ScanSetup Instance created
[HAL: 00a33bd8:play  ] cPlayback
[mb]->refreshBrowserList
[mb]->refreshFilterList 21
[neutrino] integratePlugins: add Multiboot
[neutrino] integratePlugins: add Favoriten sichern
[neutrino] integratePlugins: add Vollständiges Image-Backup
[neutrino] integratePlugins: add Benutzer-Bouquets
[neutrino] registering as event client
[neutrino] had to wait 0 ms for timerd start...
CLCD::setMuted 0
CLCD::setMuted 0
[HAL: 005e7fa8:init  ] [CEC] received message TV to all (0x00>>0x0F) 'routing change' ([0x80][0x00][0x00][0x10][0x00])
[HAL: 005e7fa8:init  ] [CEC] received message TV to all (0x00>>0x0F) 'set stream path' ([0x86][0x10][0x00])
[SDT] section 0 last 0 tsid 0x3f9 onid 0x1 -> use
[SDT] tid 3f9 onid 01
[sdt monitor] no changes.
CI: CAM not found
[neutrino] got 1275 TV and 238 RADIO channels
[neutrino] all channels took: 1 msec
[neutrino] created Astra (19.2E) (192) bouquet with 1022 TV and 208 RADIO channels
[neutrino] sat took: 1 msec
[neutrino] got 253 WebTV channels
[neutrino] got 30 WebRadio channels
[neutrino] sats took: 2 msec
[neutrino] got 120 TV and 33 RADIO bouquets
[neutrino] took: 5 msec
[neutrino.cpp:SetChannelMode:2525] newmode 0 sort old -1 new 0
[neutrino.cpp:tvMode:4938] rezap 1 current mode MODE_TV
ShowText ''
2023-09-16 03:33:11.430 [sectionsd] Reading data from file: /mnt/autofs/NAS_Stick/EPG/index.xml
CRemoteControl::tvMode
**************************** CChannelList::zapTo_ChannelID b3e003f90001ef75
**************************** CChannelList::zapToChannel me 0x9ebbf8 Alle Kanäle tuned 268435455 new ProSieben HD -> b3e003f90001ef75
2023-09-16 03:33:11.444 [sectionsd] commandserviceStopped
2023-09-16 03:33:11.444 [sectionsd] cnThread: stop eit update filter (not active)
2023-09-16 03:33:11.444 [sectionsd] commandserviceStopped done
CChannelList::adjustToChannelID me 0x9ebbf8 [Alle Kanäle] list size 1275 channel_id b3e003f90001ef75
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 1
Mode: 0
Enabled: STOP
2023-09-16 03:33:11.464 [sectionsd] commandserviceChanged: Service change to b3e003f90001ef75 demux #0
2023-09-16 03:33:11.464 [sectionsd] changeDMX: for 0x4e not ignored! even though real_pauseCounter> 0 (1)
2023-09-16 03:33:11.464 [sectionsd] changeDMX: for 0x50 not ignored! even though real_pauseCounter> 0 (1)
2023-09-16 03:33:11.465 [sectionsd] changeDMX: for 0x60 not ignored! even though real_pauseCounter> 0 (1)
CHDDDestExec::exec: hd-idle = /usr/sbin/hd-idle
[ca_ci] -> Ready param:1
[CWeather]: GetWeatherDetails
[neutrino] getUrl: url: https://api.openweathermap.org/data/2.5/onecall?lat=XX.XX&lon=Y.YY&units=metric&lang=de&exclude=minutely,hourly,flags,alerts&appid=cbdbfcafd94cc8d82daee16af5518484
[CWeather]: results found: 1694828033.000000
[CWeather]: temp in Irgendwo (Europe/Berlin): 13.5 - 01n.png
[CWeather]: temp 16.9.2023: min 13.3 - max 24.4 -> 10d.png
[CWeather]: temp 17.9.2023: min 14.3 - max 27.1 -> 04d.png
[CWeather]: temp 18.9.2023: min 14.5 - max 24.7 -> 10d.png
[CWeather]: temp 19.9.2023: min 13.1 - max 18.9 -> 10d.png
[CWeather]: temp 20.9.2023: min 13.7 - max 21.2 -> 04d.png
[CWeather]: temp 21.9.2023: min 12.1 - max 21.7 -> 10d.png
[CWeather]: temp 22.9.2023: min 11.1 - max 15.0 -> 10d.png
[CWeather]: temp 23.9.2023: min 10.9 - max 13.5 -> 10d.png
################################## after all ##################################: 10744 msec
[neutrino] initialized everything
CI: CAM not found
[zapit.cpp:StartPlayBack:2368] standby 0 playing 0 forced 0
[zapit] vpid 1FF apid 203 pcr 1FF
[HAL: 006cf060:audio ] SetStreamType 0 (0x0)
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 1
CALEN: 485
Scrambled: 1
Mode: 0
Enabled: START
No free ci-slot
CRemoteControl::handleMsg: EVT_TUNE_COMPLETE (b3e003f90001ef75)
2023-09-16 03:33:11.956 [sectionsd] commandserviceChanged: Service change to b3e003f90001ef75 demux #0
2023-09-16 03:33:12.038 [sectionsd] commandserviceChanged: Service change to b3e003f90001ef75 demux #0
[scanepg.cpp:AddTransponders:201] Added bouquet #0, scan map size: 17
[scanepg.cpp:handleMsg:275] EVT_ZAP_COMPLETE, scan map size: 17
ShowText 'ProSieben HD'
Das passiert wenn ich die den USB-Stecker (USB-->Sata von Sabrent) der HDD aus- und einstecke und somit die Platte mit dem Namen gemountet wird:
CRCInput::getMsg_us: INITID_NEUTRINO: msg a000001a size 136 data 0x9873a8
EVT_HOTPLUG: [ACTION=remove MDEV=sda1 DEVPATH=/devices/platform/f0471000.xhci/usb6/6-1/6-1:1.0/host2/target2:0:0/2:0:0:0/block/sda/sda1 DEVNAME=sda1 ]
CHDDMenuHandler::handleMsg: MDEV=sda1
CHDDMenuHandler::is_mounted: dev [/dev/sda1] is not mounted
CRCInput::getMsg_us: INITID_NEUTRINO: msg a000001a size 133 data 0x9873a8
EVT_HOTPLUG: [ACTION=add MDEV=sda1 DEVPATH=/devices/platform/f0471000.xhci/usb6/6-1/6-1:1.0/host2/target2:0:0/2:0:0:0/block/sda/sda1 DEVNAME=sda1 ]
CHDDMenuHandler::is_mounted: dev [/dev/sda1] is mounted
CHDDMenuHandler::setRecordPath: recordingdir is a symlink to /media/sda1/movies
Und hier noch ein Log, wenn die Platte mit Namen gleich richtig gemountet wird:
[dvb-sub] paused
2023-09-16 04:21:11.897 [sectionsd] Request of stop scanning (now scanning).
ShowText ' '
2023-09-16 04:21:12.380 [sectionsd] Writing Information to file: /mnt/autofs/NAS_Stick/EPG/index.tmp
2023-09-16 04:21:20.669 [sectionsd] Writing Information finished
ShowText ' '
ShowText ' '
ShowText ' '
[dvb-sub] paused
[HAL: b173cb00:demux ] Close #0: not open!
[dvb-sub] stopped
streaming shutdown
timerd shutdown
sectionsd shutdown
2023-09-16 04:21:21.757 [sectionsd] stopping...
2023-09-16 04:21:21.757 [sectionsd] eitThread::StopRun: to lock
2023-09-16 04:21:21.757 [sectionsd] eitThread::StopRun: to closefd
2023-09-16 04:21:21.757 [sectionsd] eitThread::StopRun: to unlock
2023-09-16 04:21:21.757 [sectionsd] cnThread::StopRun: to lock
2023-09-16 04:21:21.757 [sectionsd] cnThread::StopRun: to closefd
2023-09-16 04:21:21.757 [sectionsd] cnThread::StopRun: to unlock
2023-09-16 04:21:21.757 [sectionsd] timeThread::StopRun: to lock
2023-09-16 04:21:21.757 [sectionsd] timeThread::StopRun: to closefd
2023-09-16 04:21:21.757 [sectionsd] timeThread::StopRun: to unlock
2023-09-16 04:21:21.757 [sectionsd] freeSatThread::StopRun: to lock
2023-09-16 04:21:21.757 [sectionsd] freeSatThread::StopRun: to closefd
2023-09-16 04:21:21.757 [sectionsd] freeSatThread::StopRun: to unlock
2023-09-16 04:21:21.757 [sectionsd] broadcasting...
2023-09-16 04:21:21.757 [sectionsd] pausing...
2023-09-16 04:21:21.757 [sectionsd] join Housekeeping
2023-09-16 04:21:21.758 [sectionsd] join TOT
2023-09-16 04:21:21.758 [sectionsd] timeThread::Stop: to broadcast
2023-09-16 04:21:21.758 [sectionsd] timeThread::Stop: to join
2023-09-16 04:21:21.758 [sectionsd] timeThread stopped
2023-09-16 04:21:21.758 [sectionsd] timeThread::Stop: to close
2023-09-16 04:21:21.758 [sectionsd] join EIT
2023-09-16 04:21:21.758 [sectionsd] eitThread::Stop: to broadcast
2023-09-16 04:21:21.759 [sectionsd] eitThread::Stop: to join
2023-09-16 04:21:21.759 [sectionsd] eitThread stopped
2023-09-16 04:21:21.759 [sectionsd] eitThread::Stop: to close
2023-09-16 04:21:21.759 [sectionsd] join CN
2023-09-16 04:21:21.759 [sectionsd] cnThread::Stop: to broadcast
2023-09-16 04:21:21.759 [sectionsd] cnThread::Stop: to join
2023-09-16 04:21:21.759 [sectionsd] cnThread: stop eit update filter (active)
2023-09-16 04:21:21.760 [sectionsd] cnThread stopped
2023-09-16 04:21:21.760 [sectionsd] cnThread::Stop: to close
2023-09-16 04:21:21.760 [sectionsd] join FSEIT
2023-09-16 04:21:21.760 [sectionsd] freeSatThread::Stop: to broadcast
2023-09-16 04:21:21.760 [sectionsd] freeSatThread::Stop: to join
2023-09-16 04:21:21.760 [sectionsd] freeSatThread stopped
2023-09-16 04:21:21.760 [sectionsd] freeSatThread::Stop: to close
2023-09-16 04:21:21.760 [sectionsd] stopped
zapit shutdown
[HAL: 00a33bd8:play  ] ~cPlayback
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 1
Mode: 0
Enabled: STOP
[frontend.cpp:Close:365] [fe0/1] close frontend fd 8
[ca_ci] -> Stop
[ca_ci] -> ~cCA
zapit shutdown done
ShowText ' '
entering off state
timer_minutes: 0
INIT:
Sep 16 04:21:24 E4HD user.info K01camd[6900]: stop camd_datefix
Sep 16 04:21:24 E4HD user.info K01camd[6900]: stop oscam
Sep 16 04:21:28 E4HD user.info K25autofs[6993]: stopping
Sep 16 04:21:29 E4HD user.info K98fstab[7064]: unmount all netfs stuff from /etc/mtab
Sep 16 04:21:29 E4HD user.info K98network[7069]: Deconfiguring network ...
Sep 16 04:21:29 E4HD user.info rcK[7089]: start
Sep 16 04:21:29 E4HD user.info rcK[7089]: done
[ 2897.617177] reboot: Restarting system
CPU 01
BCM74390012
PRID07252112
v1.7
RR:00000200
BFW
SEC
seclib-1.5
BBL v1.0.1
AVS init...
AVS init OK
LOADED
single board
MCB: FIX
AVS start:NO
Sdram Scramble OK
BFW v2.1.0
COPY CODE... DONE
SSBL
PINMUX
CACHE FLUSH OK
MMU ON
CACHE FLUSH OK
_fbss  0704d000
_ebss  0704ea68
_end   0704ea88
HEAP @ 07100000
STACK @ 09200000
ARCH: CONFIG OK
CLR SRAM  OK
CACHE FLUSH OK
CPU CLKSET OK
GO!
Board: BCM97252SSV
SCB: 432 MHz
BOX MODE: 2
AVS: park check
AVS: V=0.971V, T=+62.809C (no AVS FW)
USB otp=00000040
[    0.000003] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
[    0.000011] Switching to timer-based delay loop, resolution 37ns
[    0.000275] Console: colour dummy device 80x30
[    0.000296] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
[    0.000407] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000414] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000871] CPU: Testing write buffer coherency: ok
[    0.001126] CPU0: update cpu_capacity 1024
[    0.001132] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001351] Setting up static identity map for 0x8440 - 0x8498
[    0.003335] smp: Bringing up secondary CPUs ...
[    0.004063] CPU1: update cpu_capacity 1024
[    0.004066] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.004128] smp: Brought up 1 node, 2 CPUs
[    0.004137] SMP: Total of 2 processors activated (108.00 BogoMIPS).
[    0.004142] CPU: All CPU(s) started in SVC mode.
[    0.004548] devtmpfs: initialized
[    0.010629] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
[    0.010817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.010832] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.046298] NET: Registered protocol family 16
[    0.046714] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.050551] cpuidle: using governor ladder
[    0.054558] cpuidle: using governor menu
[    0.062748] No ATAGs?
[    0.062821] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.062830] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.072507] SCSI subsystem initialized
[    0.072762] usbcore: registered new interface driver usbfs
[    0.072797] usbcore: registered new interface driver hub
[    0.072827] usbcore: registered new device driver usb
[    0.072868] Linux cec interface: v0.10
[    0.072898] Linux video capture interface: v2.00
[    0.072940] pps_core: LinuxPPS API ver. 1 registered
[    0.072943] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.072955] PTP clock support registered
[    0.073252] Advanced Linux Sound Architecture Driver Initialized.
[    0.073673] clocksource: Switched to clocksource arch_sys_counter
[    0.073880] FS-Cache: Loaded
[    0.078493] NET: Registered protocol family 2
[    0.078872] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.078913] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.078986] TCP: Hash tables configured (established 8192 bind 8192)
[    0.079072] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.079099] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.079206] NET: Registered protocol family 1
[    0.079482] RPC: Registered named UNIX socket transport module.
[    0.079488] RPC: Registered udp transport module.
[    0.079492] RPC: Registered tcp transport module.
[    0.079495] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.079837] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.080867] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.081361] NFS: Registering the id_resolver key type
[    0.081383] Key type id_resolver registered
[    0.081387] Key type id_legacy registered
[    0.081397] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.081401] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.081717] fuse init (API version 7.26)
[    0.083640] bounce: pool size: 64 pages
[    0.083699] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.083705] io scheduler noop registered
[    0.083709] io scheduler deadline registered
[    0.083732] io scheduler cfq registered (default)
[    0.083984] brcm-gisb-arb f0400000.gisb-arb: registered mem: f09fd000, irqs: 47, 48
[    0.084251] brcm-sata-phy f0458100.sata-phy: registered 1 port(s)
[    0.084549] brcm-cma brcm-cma.0: Initialized Broadcom CMA root device
[    0.085145] brcm-cma brcm-cma.0: Added CMA device @ PA=0x10800000 LEN=0x1f800000
[    0.085638] brcm-cma brcm-cma.1: Added CMA device @ PA=0x30000000 LEN=0xc000000
[    0.086150] brcm-cma brcm-cma.2: Added CMA device @ PA=0x80000000 LEN=0x40000000
[    0.112926] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.114215] console [ttyS0] disabled
[    0.114249] f040a900.serial: ttyS0 at MMIO 0xf040a900 (irq = 34, base_baud = 5062500) is a 16550A
[    0.842976] console [ttyS0] enabled
[    0.846972] f040a940.serial: ttyS1 at MMIO 0xf040a940 (irq = 35, base_baud = 5062500) is a 16550A
[    0.856264] f040a980.serial: ttyS2 at MMIO 0xf040a980 (irq = 36, base_baud = 5062500) is a 16550A
[    0.871954] brd: module loaded
[    0.878481] loop: module loaded
[    0.882339] OF: /rdb/sata@f045a000/sata-port@0: could not get #phy-cells for /rdb/sata-phy@f0458100
[    0.891503] brcm-ahci f045a000.sata: masking port_map 0x3 -> 0x1
[    0.897577] brcm-ahci f045a000.sata: SSS flag set, parallel bus scan disabled
[    0.914812] brcm-ahci f045a000.sata: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x1 impl platform mode
[    0.923795] brcm-ahci f045a000.sata: flags: 64bit ncq sntf stag pm clo pmp slum part
[    0.932872] scsi host0: brcm-ahci
[    0.936449] scsi host1: brcm-ahci
[    0.939915] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 44
[    0.947850] ata2: DUMMY
[    0.950316] brcm-ahci f045a000.sata: Broadcom AHCI SATA3 registered
[    0.957270] libphy: Fixed MDIO Bus: probed
[    0.961681] bcmgenet f0b00000.ethernet: GENET 4.5 EPHY: 0x1001
[    0.979684] libphy: bcmgenet MII bus: probed
[    1.006637] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.012493] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.036390] ehci-brcm: EHCI BRCM driver
[    1.040349] ehci-brcm f0470300.ehci: EHCI Host Controller
[    1.045779] ehci-brcm f0470300.ehci: new USB bus registered, assigned bus number 1
[    1.063478] ehci-brcm f0470300.ehci: irq 147, io mem 0xf0470300
[    1.065172] ata1: SATA link down (SStatus 0 SControl 300)
[    1.081679] ehci-brcm f0470300.ehci: USB 2.0 started, EHCI 1.00
[    1.088129] hub 1-0:1.0: USB hub found
[    1.091937] hub 1-0:1.0: 1 port detected
[    1.096148] ehci-brcm f0470500.ehci: EHCI Host Controller
[    1.101579] ehci-brcm f0470500.ehci: new USB bus registered, assigned bus number 2
[    1.119263] ehci-brcm f0470500.ehci: irq 148, io mem 0xf0470500
[    1.131678] ehci-brcm f0470500.ehci: USB 2.0 started, EHCI 1.00
[    1.138009] hub 2-0:1.0: USB hub found
[    1.141796] hub 2-0:1.0: 1 port detected
[    1.145929] ohci-brcm: OHCI BRCM driver
[    1.149928] ohci-brcm f0470400.ohci: BRCM OHCI controller
[    1.155355] ohci-brcm f0470400.ohci: new USB bus registered, assigned bus number 3
[    1.163004] ohci-brcm f0470400.ohci: irq 149, io mem 0xf0470400
[    1.225047] hub 3-0:1.0: USB hub found
[    1.228837] hub 3-0:1.0: 1 port detected
[    1.232979] ohci-brcm f0470600.ohci: BRCM OHCI controller
[    1.238408] ohci-brcm f0470600.ohci: new USB bus registered, assigned bus number 4
[    1.246056] ohci-brcm f0470600.ohci: irq 150, io mem 0xf0470600
[    1.308083] hub 4-0:1.0: USB hub found
[    1.311873] hub 4-0:1.0: 1 port detected
[    1.316035] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.322592] ehci-pci: EHCI PCI platform driver
[    1.327097] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.333300] ohci-pci: OHCI PCI platform driver
[    1.338064] xhci-hcd f0471000.xhci: xHCI Host Controller
[    1.343408] xhci-hcd f0471000.xhci: new USB bus registered, assigned bus number 5
[    1.351103] xhci-hcd f0471000.xhci: hcc params 0x0250f17d hci version 0x100 quirks 0x00010010
[    1.359684] xhci-hcd f0471000.xhci: irq 151, io mem 0xf0471000
[    1.366393] hub 5-0:1.0: USB hub found
[    1.370188] hub 5-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    1.377449] xhci-hcd f0471000.xhci: xHCI Host Controller
[    1.382784] xhci-hcd f0471000.xhci: new USB bus registered, assigned bus number 6
[    1.390324] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.398780] hub 6-0:1.0: USB hub found
[    1.402560] hub 6-0:1.0: 2 ports detected
[    1.406866] usbcore: registered new interface driver uas
[    1.412264] usbcore: registered new interface driver usb-storage
[    1.418589] usb 1-1: new high-speed USB device number 2 using ehci-brcm
[    1.425356] mousedev: PS/2 mouse device common for all mice
[    1.431176] i2c /dev entries driver
[    1.434923] IR NEC protocol handler initialized
[    1.439479] IR RC5(x/sz) protocol handler initialized
[    1.444551] IR RC6 protocol handler initialized
[    1.449100] IR JVC protocol handler initialized
[    1.453648] IR Sony protocol handler initialized
[    1.458286] IR SANYO protocol handler initialized
[    1.463006] IR Sharp protocol handler initialized
[    1.467727] IR MCE Keyboard/mouse protocol handler initialized
[    1.473577] IR XMP protocol handler initialized
[    1.476678] usb 2-1: new high-speed USB device number 2 using ehci-brcm
[    1.484775] smssdio: Siano SMS1xxx SDIO driver
[    1.489236] smssdio: Copyright Pierre Ossman
[    1.493851] sdhci: Secure Digital Host Controller Interface driver
[    1.500050] sdhci: Copyright(c) Pierre Ossman
[    1.504421] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.524545] hub 2-1:1.0: USB hub found
[    1.528472] hub 2-1:1.0: 4 ports detected
[    1.543683] mmc0: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
[    1.551245] hidraw: raw HID events driver (C) Jiri Kosina
[    1.556808] usbcore: registered new interface driver usbhid
[    1.562398] usbhid: USB HID core driver
[    1.568758] NET: Registered protocol family 17
[    1.573285] Key type dns_resolver registered
[    1.577634] ThumbEE CPU extension supported.
[    1.581924] Registering SWP/SWPB emulation handler
[    1.594102] ALSA device list:
[    1.597103]   No soundcards found.
[    1.601129] Waiting for root device /dev/mmcblk0p7...
[    1.676127] mmc0: new high speed MMC card at address 0001
[    1.681931] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
[    1.686623] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
[    1.692704] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
[    1.698774] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
[    1.707760]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    1.720168] EXT4-fs (mmcblk0p7): couldn't mount as ext3 due to feature incompatibilities
[    1.756499] random: fast init done
[    1.768576] EXT4-fs (mmcblk0p7): recovery complete
[    1.773878] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.782034] VFS: Mounted root (ext4 filesystem) on device 179:7.
[    1.788903] devtmpfs: mounted
[    1.792277] Freeing unused kernel memory: 340K
[    1.796736] This architecture does not have kernel memory protection.
[    1.811710] usb 2-1.2: new full-speed USB device number 3 using ehci-brcm
Jan 01 01:00:01 (none) user.info rcS[113]: start
Jan 01 01:00:01 (none) user.info rcS[113]: creating and mounting system directories ...
[    1.936758] usb 1-1: device not accepting address 2, error -71
Jan 01 00:00:15 E4HD user.info network[1204]: Configuring network ...
OSD-RES: 220 x 176
Jan 01 00:00:15 E4HD user.info S01fstab[1327]: mount all local stuff from /etc/fstab
Jan 01 00:00:15 E4HD user.info S01fstab[1327]: mount all netfs stuff from /var/etc/fstab
Jan 01 00:00:17 E4HD user.info S75autofs[1359]: starting
Jan 01 00:00:27 E4HD user.info S98camd[1580]: start camd_datefix
Jan 01 00:00:28 E4HD user.info camd_datefix[1583]: manipulating date ...
Sep 16 04:21:00 E4HD user.info camd_datefix[1583]: done (202309160421)
Sep 16 04:21:00 E4HD user.info S98camd[1580]: start oscam
[ca_ci] -> cCA 1
component: ca      0x40
[HAL: bef5ac5c:power ] SetCpuFreq(0) => set standby = false
ShowText ''
ShowText ' '
ShowText 'NI \o/'
[fe0/1] frontend fd 10 type 0
[zapit] service loading took: 28 msec
[zapit] bouquet loading took: 191 msec
[ca_ci] -> Start
[zapit] starting... tid 1696
[rcinput:open] opened /dev/input/event3 (fd 30) ev 0x100013
[rcinput:open] opened /dev/input/event2 (fd 31) ev 0x3
[rcinput:open] opened /dev/input/event1 (fd 32) ev 0x100003
[rcinput:open] opened /dev/input/event0 (fd 33) ev 0x100003
[fe0/0] tuning took: 285 msec (min 285 max 285)
[HAL: b0101ec8:demux ] _open: setting /dev/dvb/adapter0/demux0 to source 0
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 1
CALEN: 485
Scrambled: 1
Mode: 0
Enabled: START
No free ci-slot
timerd startup, tid 1859
[yhttpd] Webserver nhttpd/3.4.1 (yhttpd_core/1.3.2) tid 1862
2023-09-16 04:21:07.795 [sectionsd] start
2023-09-16 04:21:07.795 [sectionsd] Caching: 14 days, 360 hours Extended Text, max 150000 events, Events are old 1 hours after end time
2023-09-16 04:21:07.795 [sectionsd] NTP: enabled, command /usr/sbin/ntpdate 0.de.pool.ntp.org
Starting STREAM thread keeper, tid 1863
[HAL: b0b21530:demux ] Stop #0: not open!
2023-09-16 04:21:07.795 [sectionsd] starting
2023-09-16 04:21:07.795 [sectionsd] SIevent size: 92
2023-09-16 04:21:07.795 [sectionsd] ====> USING SLOW ADDEVENT. export 'NO_SLOW_ADDEVENT=1' to avoid <===
2023-09-16 04:21:07.801 [sectionsd] timeThread::run:: starting, pid 1642 (2869908480)
2023-09-16 04:21:07.808 [sectionsd] eitThread::run:: starting, pid 1642 (2861515776)
2023-09-16 04:21:07.831 [sectionsd] cnThread::run:: starting, pid 1642 (2853123072)
2023-09-16 04:21:07.831 [sectionsd] freeSatThread::run:: starting, pid 1642 (2844730368)
CI: CAM not found
CI: CAM not found
[HAL: 0074dac0:play  ] cPlayback
CLCD::setMuted 0
CLCD::setMuted 0
CI: CAM not found
[neutrino] took: 3 msec
ShowText ''
2023-09-16 04:21:10.926 [sectionsd] Reading data from file: /mnt/autofs/NAS_Stick/EPG/index.xml
**************************** CChannelList::zapToChannel me 0x96c550 Alle Kanäle tuned 268435455 new ProSieben HD -> b3e003f90001ef75
2023-09-16 04:21:10.938 [sectionsd] commandserviceStopped
2023-09-16 04:21:10.938 [sectionsd] cnThread: stop eit update filter (not active)
2023-09-16 04:21:10.938 [sectionsd] commandserviceStopped done
CChannelList::adjustToChannelID me 0x96c550 [Alle Kanäle] list size 1275 channel_id b3e003f90001ef75
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 1
Mode: 0
Enabled: STOP
2023-09-16 04:21:10.958 [sectionsd] commandserviceChanged: Service change to b3e003f90001ef75 demux #0
2023-09-16 04:21:10.959 [sectionsd] changeDMX: for 0x4e not ignored! even though real_pauseCounter> 0 (1)
2023-09-16 04:21:10.959 [sectionsd] changeDMX: for 0x50 not ignored! even though real_pauseCounter> 0 (1)
2023-09-16 04:21:10.959 [sectionsd] changeDMX: for 0x60 not ignored! even though real_pauseCounter> 0 (1)
[CWeather]: results found: 1694830933.000000
[CWeather]: temp in Irgendwo (Europe/Berlin): 13.4 - 01n.png
[CWeather]: temp 16.9.2023: min 13.2 - max 24.4 -> 10d.png
################################## after all ##################################: 10283 msec
TP: B3E003F90001
SID: EF75
SOURCE: 0
CA_MASK: 1
CALEN: 485
Scrambled: 1
Mode: 0
Enabled: START
No free ci-slot
CI: CAM not found
2023-09-16 04:21:11.611 [sectionsd] commandserviceChanged: Service change to b3e003f90001ef75 demux #0
2023-09-16 04:21:11.674 [sectionsd] commandserviceChanged: Service change to b3e003f90001ef75 demux #0
CLCD::ShowDiskLevel 29
2023-09-16 04:21:11.827 [sectionsd] Reading data finished after 616 ms (16 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/SamsungTVPlus/at.xml
2023-09-16 04:21:11.865 [sectionsd] Reading data finished after 632 ms (16 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/SamsungTVPlus/ch.xml
2023-09-16 04:21:11.893 [sectionsd] Reading data finished after 624 ms (16 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/SamsungTVPlus/de.xml
Achso, die Platte sollte mit "bar2tb" angesprochen werden können (soll für Barracuda 2TB stehen).
