Lua plugin camera with rtsp protocol
jaro44
Box: tank, trinity duo, xsarius alpha hd
Beitrag von jaro44 »
I'ts possible build lua with socket for this camera plugin to work?:
-- Załadowanie biblioteki lua-socket
local socket = require("socket")
-- Określenie adresu IP kamery oraz portu RTSP
local camera_ip = "192.168.1.100"
local rtsp_port = 554
-- Wysłanie żądania DESCRIBE, aby uzyskać informacje o strumieniu
local describe_request = "DESCRIBE rtsp://" .. camera_ip .. ":" .. rtsp_port .. "/stream RTSP/1.0\r\n" ..
                         "CSeq: 1\r\n" ..
                         "Accept: application/sdp\r\n\r\n"
local describe_socket = assert(socket.connect(camera_ip, rtsp_port))
describe_socket:send(describe_request)
-- Odczytanie odpowiedzi od kamery
local describe_response = ""
while true do
    local chunk, status, partial = describe_socket:receive("*a")
    describe_response = describe_response .. (chunk or partial)
    if status == "closed" then
        break
    end
end
-- Wyodrębnienie adresu strumienia z odpowiedzi DESCRIBE
local stream_address = string.match(describe_response, "m=video%s+(.-)%s+")
-- Wysłanie żądania SETUP, aby nawiązać połączenie z kamery
local setup_request = "SETUP rtsp://" .. camera_ip .. ":" .. rtsp_port .. "/" .. stream_address .. " RTSP/1.0\r\n" ..
                      "CSeq: 2\r\n" ..
                      "Transport: RTP/AVP;unicast;client_port=5000-5001\r\n\r\n"
local setup_socket = assert(socket.connect(camera_ip, rtsp_port))
setup_socket:send(setup_request)
local setup_response = ""
while true do
    local chunk, status, partial = setup_socket:receive("*a")
    setup_response = setup_response .. (chunk or partial)
        break
    end
end
-- Wysłanie żądania PLAY, aby rozpocząć odtwarzanie strumienia
local play_request = "PLAY rtsp://" .. camera_ip .. ":" .. rtsp_port .. "/" .. stream_address .. " RTSP/1.0\r\n" ..
                     "CSeq: 3\r\n" ..
                     "Range: npt=0.000-\r\n\r\n"
local play_socket = assert(socket.connect(camera_ip, rtsp_port))
play_socket:send(play_request)
local play_response = ""
while true do
    local chunk, status, partial = play_socket:receive("*a")
    play_response = play_response .. (chunk or partial)
        break
    end
end
-- Otworzenie gniazda UDP do odbierania pakietów RTP
local udp_socket = assert(socket.udp())
udp_socket:setsockname("*", 5000)
-- Odbieranie i przetwarzanie pakietów RTP
while true do
    local data, ip, port = udp_socket:receivefrom()
    -- Tutaj można umieścić kod przetwarzający pakiet RTP
end
Has thanked: 18 times
Been thanked: 19 times
Re: Lua plugin camera with rtsp protocol
did you write the plugin yourself ?
good idea ... vanhofen is his wish feasible ?
Has thanked: 10 times
Been thanked: 27 times
Don't know.
jaro44
it's a pity, there is no python, and lua is very limited :frowning2:
do not despair right away, give vanhofen a little time. he also has to read up first ... see
https://lunarmodules.github.io/luasocket/
Höre auf, mich hier vors Loch zu schieben.
yes sir
jaro44 ..
which camera do you have .. maybe it supports other protocols
jaro44
jokel hat geschrieben: Fr 24. Mär 2023, 19:54 yes sir
jaro44 ..
No, only rtsp.
so, I see that the neutrino has run out and this relic must be thrown into the trash.
It's time to invest in box with better support.
Thx and good luck.
Been thanked: 13 times
LUA is not needed, why not using webtv?!
Example:
<webtv title="!RTSP-TEST" url="rtsp://wowzaec2demo.streamlock.net/vod/mp4%3ABigBuckBunny_115k.mp4" description=""/>
Works without problems.
BPanther hat geschrieben: Mo 27. Mär 2023, 11:54 LUA is not needed, why not using webtv?!
Example:
good alternative ...
i also have an ip camera and will experiment with ffmpeg
neutrino still has many possibilities to offer
jaro44
Example:
Of course BP, it works, but there are no configuration options as if it were possible in a plugin :(
search the internet ... for "camera curl command PLZ".
maybe you can configure and control your camera with it
with a bash-script ?
