No signal after update to new Nightly
jaro44
Box: tank, trinity duo, xsarius alpha hd
Beitrag von jaro44 »
After update image on my box I don't have signal ( I reset to factory default and is same)
I back to 3.40 and all is ok, so I install newest nightly from usb and again is "no signal"
I had to go back to the old image :(
PS.
My antenna instalation:
multiswitch
diseqc 1.0
hotbird 13E - 1
astra 19.2E - 2
Re: No signal after update to new Nightly
Have you tried without own settings? SAT Scan also done and not your old Zapit?
jaro44
after update I make factory reset and make new configuration, so this is no problem with config.
with box and instalation also, because on old 3.40 image all work ok
If you came from NI, you don't need a factory Resett. 3.4 is more than 2 years old, I don't know all the changes in 2 years. Have you tryed with other diseqc Settings?
jaro44
I had 3.60 from November, and this I update yesterday and have those probleme :(
Zuletzt geändert von jaro44 am Fr 3. Jan 2020, 20:45, insgesamt 1-mal geändert.
You mean yesterday not tomorrow? Why 3.6 from November?
I don't understand really what you wrote.
jaro44
yes yesterday, my mistake
previous last update nightly 3.60 I did in November, and he worked ok until yesterday
Been thanked: 19 times
my both tanks and the zee² works with the nightlies from today (03.01.) without problems.
jaro44
with same antena and diseqc instalation?
I now install keywelt 3,92 and also work ok for me, newest NI not
My Tank Image is from 20.12.19 and everything okay. Can't update it now but tewsbo with 3 boxes should be enough.
jaro44 hat geschrieben: Fr 3. Jan 2020, 20:57 with same antena and diseqc instalation?
yes, diseqc etc. the same - see for my sat-settings also my signature.
jaro44
so, with my instalation this is bug for me (multiswitch with diseqc 13E - 1, 19,2E - 2)
I wait for fix and stay with newest keywelt, because it work ok
No problem. It can only be solved by providing a log.
jaro44
ok, I'll try to log it after weekend
nofx
Beitrag von nofx »
I have similar issues see log..
astra 19.2E - ok, no issues
hotbird 13E - issues
[fe0/0] Diseqc cmd: 0xE0 0x10 0x38 0xF4
[fe0/0] Diseqc cmd: 0xE1 0x10 0x38 0xF4
[fe0/0] tune to 10758000 DVB-S2 8PSK 3/4 V/R srate 27500000 pli 0 plc 1 plm 0 (tuner 1008000 offset 9750000 timeout 4000)
[sdt monitor] wakeup...
[sdt monitor] TP already updated less than an hour ago.
[fe0/0] ############################## poll timeout, time: 4020 msec (min 2000 max 4064)
[zapit] ZapIt:1 SCR retry tuning 1 after 4ms
CRemoteControl::handleMsg: EVT_TUNE_COMPLETE (0000000000000000)
CVFD::showServicename: (4Fun.TV)
CVFD::ShowText: [0x10][(4Fun.TV)]
zap failed!
jaro44
install the latest keywelt_Jun2019_V3.92 and everything will be ok
jaro44 hat geschrieben: Mo 13. Jan 2020, 19:27 install the latest keywelt_Jun2019_V3.92 and everything will be ok
I still wait for your log.
jaro44
Miky hat geschrieben: Mo 13. Jan 2020, 19:34
everything works fine on keywelt, so i didn't reinstall it to NI,
maybe I'll log it in my spare time, but as You can see the problem is more widespread,not only at my box
jaro44 hat geschrieben: Fr 3. Jan 2020, 21:26 ok, I'll try to log it after weekend
If you won't log, no help possible.
Otherwise are post likes : "Use Keywelt and everything ist easy" not really helpful.
You posted and asked for support but you are not able to flash NI again for logging?Incomprehensible.
nofx
Beitrag von nofx »
Last working img (own build) is from 2019.11.14, the next one which I have is from 2019.12.27 and since them I have these kind of issues with hotbird 13E.
So something was changed between these dates.
Zurück zu „Apollo (TANK)“
