Cables.xml für Vodafone Kabel Deutschland
Peter59
Box: VU+
Beitrag von Peter59 »
Hier mal die aktuelle cables.xml für Vodafone Kabel Deutschlnd.
Diese enthält alle genutzten Frequenzen unabhängig von der jeweiligen Kabel Ausbaustufe.
	<cable name="Vodafone Kabel Deutschland" satfeed="true" flags="9" countrycode="DEU">
		<transponder frequency="73000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="122000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="466000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="474000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="482000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="490000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="498000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="522000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="530000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="538000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="546000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="554000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="562000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="570000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="578000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="586000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="594000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="610000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		</cable>
Die vorhanden Kabel Deutschland Einträge können somit entfernt werden.
palace
Re: Cables.xml für Vodafone Kabel Deutschland
Beitrag von palace »
Hi, funktioniert die auch für das ehemalige KabelBW Gebiet?
Bei mir werden ein Haufen Sender nicht gefunden.
U.a. das gesamte ARD und ZDF Buquet.
Has thanked: 20 times
Been thanked: 40 times
scanne mit NIT gleich EIN, dann sollte alles gefunden werden, mit jeder Liste... ;)
Has thanked: 171 times
Don de Deckelwech hat geschrieben: So 21. Feb 2021, 19:47 Hi,
Funktioniert allerdings nicht mit VU+ Uno4kSE
palace
Danke, habe ich gemacht. Hilft aber nicht. Es werden nur etwa 290 Sender gefunden.
Ich weiß, dass Sender, die nicht gefunden werden, vor dem Scan funktionierten.
Z.B. „Das Erste“ oder „ZDF HD“.
Ich bin auf einer ZEE2 unterwegs.
Interessanter Weise verhielt sich das bei einem Kumpel identisch.
Nur der hat die „Chance“ genutzt, direkt auf eine Dream umzusteigen.
Gibt es hier noch einen User aus BW, der mir aktuelle Services, Bouquets und das dritte (fällt mir grad nicht ein) zur Verfügung stellen kann?
palace
mirz hat geschrieben: Di 23. Feb 2021, 01:14 ist hier nichts zu finden?
https://helpdesk.vodafonekabelforum.de/ ... egung.html
Cool, danke. Den kannte ich nicht.
palace hat geschrieben: Mo 22. Feb 2021, 20:44 Danke, habe ich gemacht. Hilft aber nicht. Es werden nur etwa 290 Sender gefunden.
Dann hat Vodafone in der Tat keine funktionierende NIT.
Peter59
Box: VU+
palace hat geschrieben: So 21. Feb 2021, 19:36 Hi, funktioniert die auch für das ehemalige KabelBW Gebiet?
Nein, die funktioniert nicht für das exUM Gebiet, nur für wie im Betreff erwähnt exKabel Deutschland.
Für das exUM Gebiet dürfte die cables.xml nutzbar sein:
<?xml version="1.0" encoding="iso-8859-1"?>
<cables>
	<cable name="Unitymedia" satfeed="true" flags="9" countrycode="DEU">
		<transponder frequency="114000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="122000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="130000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="138000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="146000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="154000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="162000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="170000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="178000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="186000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="194000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="202000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="210000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="218000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="226000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="234000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="242000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="250000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="258000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="266000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="274000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="282000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="290000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="298000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="306000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="314000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="322000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="610000" symbol_rate="6900000" fec_inner="9" modulation="3"/>
	</cable>
	</cables>
Has thanked: 66 times
Been thanked: 208 times
nachdem vodafone hier in berlin bissel im kabel was umgestellt hat ..
hier die aktuelle cables.xml für berlin .. die kanalsuche war in 30 sek. erledigt.
kleiner tipp am rande .. löscht vorher die ..
/var/tuxbox/config/zapit/services.xml
cables.xml
(2.85 KiB) 115-mal heruntergeladen
Nanobot
Been thanked: 8 times
Beitrag von Nanobot »
Hierzu der Hinweis von mir: Die Umstellung findet in Berlin in den einzelnen Stadtbezirken zu verschiedenen Zeitpunkten statt, welche man hier ersehen kann:
https://helpdesk.vodafonekabelforum.de/ ... ng-11.html
Ich habe zusätzlich eine Email erhalten, in der ich über den bei mir zutreffenden Zeitpunkt informiert worden bin. Das kann aber natürlich nur dann passieren, wenn man den Kabelanschluß "offiziell" hat und Vodafone daher eine Email Adresse kennt.
@jokel
Was sollen denn die ersten drei Zeilen in der Datei von dir darstellen ? Dies sind doch gar keine TV-Frequenzen, oder benutzt die "Gigabox" diese Frequenzen irgendwie ?
die datei wurde von vodafone erstellt bzw. habe ich sie erstellen lassen ..
und ja die 3 zeilen kannst du löschen .. sie bringen keinen mehrwert bzw. nutzen.
bei mir war das problem das jetzt durch die mehrmalige umstellung im kabel ..
ich nach der kanalsuche viele sender doppelt drin hatte ..
also habe ich die services.xml gelöscht .. rebootet und danach mit der neuen cables.xml ..
eine auto-kanalsuche gestartet .. und habe jetzt eine jungfräuliche services.xml ..
ohne doppelten einträge mehr.
es wurden 342 sender (tv+radio) gefunden .. wird immer weniger :nerd:
Nanobot
Ja, die Zahl der Sender wird einerseits dadurch weniger, daß viele Sender nur noch in HD gesendet werden und die SD Ausstrahlung beendet wurde. Um zum anderen wurden ja viele der Sky Sender auf IPTV umgestellt.
Ich träume ja immer noch davon, daß die privaten werbefinanzierten Sender endlich einsehen daß es von den meisten Verbrauchern nicht akzeptiert wird, daß man für Werbung in HD extra bezahlen soll. Sprich, sowohl die SAT1, als auch die RTL Gruppe sollten die Verschlüsselung der HD Versionen aufgeben und die SD Abstrahlung ihrer Sender ebenfalls beenden. Dann wäre noch viel mehr Platz im Kabelnetz für andere Sachen.
Zurück zu „Senderlisten“
