DVB-T/T2
EnoSat
Box: MIO4K+ & HD51 & Solo4K
DVB-T/T2
Beitrag von EnoSat »
How to scan DVB-T / T2 in Solo4K? It only shows DVB-C.
/var/root # dvbsnoop -s feinfo -frontend /dev/dvb/adapter0/frontend8 -pd 9
dvbsnoop V1.4.5X -- http://dvbsnoop.sourceforge.net/
   DEMUX : /dev/dvb/adapter0/demux0
   DVR   : /dev/dvb/adapter0/dvr0
   FRONTEND: /dev/dvb/adapter0/frontend8
FrontEnd Info...
Device: /dev/dvb/adapter0/frontend8
Basic capabilities:
    Frontend-type:       QAM (DVB-C)
    Frequency (min):     47000.000 kHz
    Frequency (max):     862000.000 kHz
    Frequency stepsiz:   62.500 kHz
    Frequency tolerance: 0.000 kHz
    Symbol rate (min):     0.870000 MSym/s
    Symbol rate (max):     11.700000 MSym/s
    Symbol rate tolerance: 0 ppm
    Notifier delay: 0 ms
    Frontend capabilities:
        auto inversion
        FEC AUTO
        QAM 16
        QAM 32
        QAM 64
        QAM 128
        QAM 256
Current parameters:
    Frequency:  0.000 kHz
    Inversion:  OFF
    Symbol rate:  0.000000 MSym/s
    FEC:  FEC AUTO
    Modulation:  QAM AUTO
/var/root #
/var/root # cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-S2
        Name: Vuplus DVB-S NIM(7376 FBC)
        Frontend_Device: 0
NIM Socket 1:
        Type: DVB-S2
        Frontend_Device: 1
NIM Socket 2:
        Type: DVB-S2
        Frontend_Device: 2
NIM Socket 3:
        Type: DVB-S2
        Frontend_Device: 3
NIM Socket 4:
        Type: DVB-S2
        Frontend_Device: 4
NIM Socket 5:
        Type: DVB-S2
        Frontend_Device: 5
NIM Socket 6:
        Type: DVB-S2
        Frontend_Device: 6
NIM Socket 7:
        Type: DVB-S2
        Frontend_Device: 7
NIM Socket 8:
        Type: DVB-C
        Name: Vuplus DVB-C NIM(SSH108)
        Mode 0: DVB-C
        Mode 1: DVB-T2
        Frontend_Device: 8
        I2C_Device: 4
PS: after select Multiboot show this screen
Gibertini OP100L /85E-53W/
Has thanked: 17 times
Been thanked: 37 times
Re: DVB-T/T2
regarding the multiboot-error: does exist a file "/boot/STARTUP" and what is inside (it is just a textfile)?
Bye,
EnoSat
Re: DVB-T/T2
