NI-Buildsystem
Has thanked: 55 times
Been thanked: 32 times
Re: NI-Buildsystem
Mir kackt allerdings beim Bau vom Kernel der HD60 der build ab.
CC [M]  fs/xfs/libxfs/xfs_ialloc.o
  CC [M]  fs/xfs/libxfs/xfs_ialloc_btree.o
  CC [M]  fs/xfs/libxfs/xfs_inode_fork.o
  CC [M]  fs/xfs/libxfs/xfs_inode_buf.o
  CC [M]  fs/xfs/libxfs/xfs_log_rlimit.o
  CC [M]  fs/xfs/libxfs/xfs_sb.o
  CC [M]  fs/xfs/libxfs/xfs_symlink_remote.o
  CC [M]  fs/xfs/libxfs/xfs_trans_resv.o
  CC [M]  fs/xfs/libxfs/xfs_rtbitmap.o
  CC [M]  fs/xfs/xfs_aops.o
  CC [M]  fs/xfs/xfs_attr_inactive.o
  CC [M]  fs/xfs/xfs_attr_list.o
  CC [M]  fs/xfs/xfs_bmap_util.o
  CC [M]  fs/xfs/xfs_buf.o
  CC [M]  fs/xfs/xfs_dir2_readdir.o
  CC [M]  fs/xfs/xfs_discard.o
  CC [M]  fs/xfs/xfs_error.o
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_inode.h:22,
                 von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c:28:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c: In Funktion »xfs_swap_extents_check_format«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/libxfs/xfs_inode_fork.h:90:42: Warnung: »<<« in booleschem Kontext, meinten Sie »<«? [-Wint-in-bool-context]
   90 | #define XFS_IFORK_BOFF(ip)              ((int)((ip)->i_d.di_forkoff << 3))
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c:1668:21: Anmerkung: bei Substitution des Makros »XFS_IFORK_BOFF«
 1668 |                 if (XFS_IFORK_BOFF(ip) &&
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_bmap_util.c:1678:21: Anmerkung: bei Substitution des Makros »XFS_IFORK_BOFF«
 1678 |                 if (XFS_IFORK_BOFF(tip) &&
  CC [M]  fs/xfs/xfs_export.o
  CC [M]  fs/xfs/xfs_extent_busy.o
  CC [M]  fs/xfs/xfs_file.o
  CC [M]  fs/xfs/xfs_filestream.o
  CC [M]  fs/xfs/xfs_fsops.o
  CC [M]  fs/xfs/xfs_globals.o
  CC [M]  fs/xfs/xfs_icache.o
  CC [M]  fs/xfs/xfs_ioctl.o
  CC [M]  fs/xfs/xfs_iomap.o
  CC [M]  fs/xfs/xfs_iops.o
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_fsops.c:21:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_fsops.c: In Funktion »xfs_growfs_data_private«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/libxfs/xfs_format.h:768:17: Warnung: Zugriff auf die Adresse des gepackten Elements von »struct xfs_agfl« führt möglicherweise zu einem nicht ausgerichteten Zeigerwert [-Waddress-of-packed-member]
  768 |                 &(XFS_BUF_TO_AGFL(bp)->agfl_bno[0]) : \
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_fsops.c:279:28: Anmerkung: bei Substitution des Makros »XFS_BUF_TO_AGFL_BNO«
  279 |                 agfl_bno = XFS_BUF_TO_AGFL_BNO(mp, bp);
  CC [M]  fs/xfs/xfs_inode.o
  CC [M]  fs/xfs/xfs_itable.o
  CC [M]  fs/xfs/xfs_message.o
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c: In Funktion »xfs_handle_to_dentry«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c:182:25: Warnung: die Umwandlung eines gepackten Zeigers auf »struct xfs_fid64« (Ausrichtung 1) in einen Zeiger auf »struct fid« (Ausrichtung 4) führt möglicherweise zu einem nicht ausgerichteten Zeiger [-Waddress-of-packed-member]
  182 |                         xfs_handle_acceptable, NULL);
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c:37:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_export.h:62:8: Anmerkung: hier definiert
   62 | struct xfs_fid64 {
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.h:21,
                 von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_linux.h:94,
                 von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs.h:32,
                 von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_ioctl.c:18:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/include/linux/exportfs.h:105:8: Anmerkung: hier definiert
  105 | struct fid {
  CC [M]  fs/xfs/xfs_mount.o
  CC [M]  fs/xfs/xfs_mru_cache.o
  CC [M]  fs/xfs/xfs_stats.o
  CC [M]  fs/xfs/xfs_super.o
  CC [M]  fs/xfs/xfs_symlink.o
  CC [M]  fs/xfs/xfs_sysfs.o
  CC [M]  fs/xfs/xfs_trans.o
  CC [M]  fs/xfs/xfs_xattr.o
  CC [M]  fs/xfs/kmem.o
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_xattr.c: In Funktion »xfs_xattr_put_listent«:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_xattr.c:186:9: Warnung: »strncpy« Ausgabe möglicherweise abgeschnitten, beim Kopieren von 5 bis 9 Byte aus einer Zeichenkette der Länge 9 [-Wstringop-truncation]
  186 |         strncpy(offset, xfs_xattr_prefix(flags), prefix_len);
  CC [M]  fs/xfs/uuid.o
  CC [M]  fs/xfs/xfs_log.o
In Datei, eingebunden von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_linux.h:53,
                 von /media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:19:
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/include/linux/module.h:130:13: Warnung: »init_module« legt weniger eingeschränktes Attribut als sein Ziel »init_xfs_fs« fest: »cold« [-Wmissing-attributes]
  130 |         int init_module(void) __attribute__((alias(#initfn)));
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1942:1: Anmerkung: bei Substitution des Makros »module_init«
 1942 | module_init(init_xfs_fs);
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1826:1: Anmerkung: Ziel »init_module« wurde hier deklariert
 1826 | init_xfs_fs(void)
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/include/linux/module.h:136:14: Warnung: »cleanup_module« legt weniger eingeschränktes Attribut als sein Ziel »exit_xfs_fs« fest: »cold« [-Wmissing-attributes]
  136 |         void cleanup_module(void) __attribute__((alias(#exitfn)));
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1943:1: Anmerkung: bei Substitution des Makros »module_exit«
 1943 | module_exit(exit_xfs_fs);
/media/knicko/bs-systeme/ni-org/ni-buildsystem/build_tmp/linux-4.4.35/fs/xfs/xfs_super.c:1923:1: Anmerkung: Ziel »cleanup_module« wurde hier deklariert
 1923 | exit_xfs_fs(void)
  CC [M]  fs/xfs/xfs_log_cil.o
  CC [M]  fs/xfs/xfs_buf_item.o
  CC [M]  fs/xfs/xfs_extfree_item.o
  CC [M]  fs/xfs/xfs_icreate_item.o
  CC [M]  fs/xfs/xfs_inode_item.o
  CC [M]  fs/xfs/xfs_log_recover.o
  CC [M]  fs/xfs/xfs_trans_ail.o
  CC [M]  fs/xfs/xfs_trans_buf.o
  CC [M]  fs/xfs/xfs_trans_extfree.o
  CC [M]  fs/xfs/xfs_trans_inode.o
  CC [M]  fs/xfs/xfs_rtalloc.o
  CC [M]  fs/xfs/xfs_acl.o
  CC [M]  fs/xfs/xfs_sysctl.o
  LD [M]  fs/xfs/xfs.o
  LD      fs/built-in.o
make[1]: *** [Makefile:150: sub-make] Fehler 2
knicko@knicko-Lenovo-ideapad-330-15IKB:/media/knicko/bs-systeme/ni-org/ni-buildsystem$
Keine Ahnung, warum er da mt xfs jetzt ein Problem hat.
Hatte bei oe-a auch mal da in die defconfig geschaut, ob sich da was Gravierendes geändert hat, aber da ist nichts, was den Fehler verursachen könnte.
Has thanked: 17 times
Been thanked: 41 times
Re: NI-Buildsystem
Den eigentlichen Fehler sehe ich nicht im Log-Auszug. Scheint nicht wirklich bei XFS zu sein, denn das sind da nur Warnungen. Oder der ist davor, nur fehlt das im Log.
Re: NI-Buildsystem
Ich denke, da fehlen ein paar Kernel-Patches. Vielleicht komme ich morgen dazu.
Re: NI-Buildsystem
Danke Sven.
Ja, das war der Grund.
Wünsche Euch ein schönes Wochenende.
l.Gr. Knicko
Has thanked: 39 times
Been thanked: 139 times
Re: NI-Buildsystem
jo baut durch
make flash-image
make flash-image-hd5x
rm -rf /home/jokel/ni-buildsystem/build_tmp/image-build
/usr/bin/install -d /home/jokel/ni-buildsystem/build_tmp/image-build/zgemma/h7
cp /home/jokel/ni-buildsystem/build_tmp/linux-4.10.12-obj/arch/arm/boot/zImage_dtb /home/jokel/ni-buildsystem/build_tmp/image-build/zgemma/h7/kernel.bin
set -e; cd /home/jokel/ni-buildsystem/build_tmp/rootfs/linuxrootfs1; \
tar -cvf /home/jokel/ni-buildsystem/build_tmp/image-build/zgemma/h7/rootfs.tar -C /home/jokel/ni-buildsystem/build_tmp/rootfs/linuxrootfs1 . >/dev/null 2>&1; \
bzip2 /home/jokel/ni-buildsystem/build_tmp/image-build/zgemma/h7/rootfs.tar
# Create minimal image
set -e; cd /home/jokel/ni-buildsystem/build_tmp/image-build/zgemma/h7; \
tar -czf /home/jokel/ni-buildsystem/staging/images/ni411-202205211543-arm-h7.tgz kernel.bin rootfs.tar.bz2
echo http://neutrino-images.de/neutrino-imag ... arm-h7.tgz 9411202205211543 $(md5sum /home/jokel/ni-buildsystem/staging/images/ni411-202205211543-arm-h7.tgz | cut -c1-32) ""Air Digital Zgemma H7" [arm-h7] Selfmade" 4.11.141.141 >> /home/jokel/ni-buildsystem/staging/images/selfmade-arm-h7.txt
#make flash-image-hd5x-multi
Done
jokel@jokel-ThinkPad:~/ni-buildsystem$
Re: NI-Buildsystem
Was ist mit dem Buildfehler, der vor 10 Minuten noch von dir gepostet wurde?
jokel hat geschrieben: Sa 21. Mai 2022, 15:50 ... ""Air Digital Zgemma H7" [arm-h7] Selfmade" 4.11.141.141
Nice. :grinning:
Re: NI-Buildsystem
ice32 hatte mir geschrieben "mach mal make clean" und mach nochmal "make image"
danach ging es :wink:
hatte ich wohl vergessen (a1)
neutrino-allgemein-f4/ni-buildsystem-t1 ... tml#p34935
vanhofen top :slight_smile:
Zuletzt geändert von jokel am Sa 21. Mai 2022, 16:27, insgesamt 3-mal geändert.
Re: NI-Buildsystem
Ein Guter, der ice. :smiley:
Has thanked: 28 times
Been thanked: 19 times
Re: NI-Buildsystem
@jokel
warum steht im screenshot eigentlich nicht...
Ersteller: NI-Buildsystem, ice32
? :upside_down:
Re: NI-Buildsystem
@dryeye
ich gebe dir recht. ich bin halt noch nicht so fit wie ice32 und lerne aus meinen fehlern.
theoretisch müsste dort @vanhofen stehen.
max_10
Re: NI-Buildsystem
Beitrag von max_10 »
Wenn ice32 das Image selber gebaut hat stimmt das schon so, wie es da steht.
Re: NI-Buildsystem
Re: NI-Buildsystem
ja, da der cache auch neu musste, hat der Server mal 13 Stunden gerödelt- :grinning:
Fleißiges Kerlchen :stuck_out_tongue:
Wird also demnächst wieder früher mit den Images fertig sein.
Re: NI-Buildsystem
ich hatte ja das nI-buildsystem aktualisiert. problem ist jetzt das im lcd display die bar nur noch einfarbig
dargestellt wird. da wurde geschraubt wie ich sehe
https://github.com/TangoCash/lcd4linux/ ... 4e363dd4e9
im image davor ist die bar noch zweifarbig und aktuell jetzt nur einfarbig.
kann das bitte mal jemand gegenchecken.
bild 1 ist alte image
bild 2 ist neues image
Has thanked: 14 times
Been thanked: 14 times
Re: NI-Buildsystem
Fehler liegt bei deinen Änderungen
Gerade frisch geflasht und eigene lcd Daten eingespielt:
Re: NI-Buildsystem
annie ich habe nichts geändert.
einziger unterschied ist alte image zum neuen.
und zur bar. das sind eigentlich zwei. grün geht von links nach rechts u. rot geht von rechts nach links
bar 1 grün ist layer 2 u. bar 2 rot ist layer 3,also recht kompliziert. leider habe ich vom alten buildsystem kein
backup :disappointed_relieved:
und die rote bar wird nicht mehr dargestellt bzw. gezeichnet
Re: NI-Buildsystem
Jokel, Das Buildsystem ist ganz sicher nicht verantwortlich, wenn du dir rote und grüne Bilder nicht ins Image kopierst. Und der von dir oben angesprochene Patch ist dafür auch nicht verantwortlich.
Re: NI-Buildsystem
vanhofen hat geschrieben: Mo 23. Mai 2022, 12:35 Jokel, Das Buildsystem ist ganz sicher nicht verantwortlich, wenn du dir rote und grüne Bilder nicht ins Image kopierst. Und der von dir oben angesprochene Patch ist dafür auch nicht verantwortlich.
nein am nI-buildsystem liegt es nicht aber an der lcd4linux quelle
und genau da lag der fehler. ich habe das mal rückgängig gemacht u. neu compiliert
ergebnis
Zuletzt geändert von jokel am Mo 23. Mai 2022, 14:22, insgesamt 1-mal geändert.
Re: NI-Buildsystem
so muss das aussehen. rote bar von rechts nach links.
vanhofen und ohne bildchen :wink:
tango :wink:
Re: NI-Buildsystem
habe mir gerade eben das aktuelle image gebau / geflasht
wenn die box hochfährt ist die lautstärke bei 100% das mir bald die ohren abfallen
ist das neu ?
