Starting (Emergency Flash)
volme
Beitrag von volme »
Hallo ,
bekomme meine Tank nicht aus dem "Starting" Bereich , die 3 Dateien auf dem USB Stick usw.
aber die Box zickt .....
als Anhang den Log ( was ich selbst erkennen konnte waren u.a. "Bad Blocks"
Starting Microloader ASM built on Jan 08 2014 14:32:26...
Initializing PLLs...
Initializing Clocks..
Initializing data section...
Initializing stack ptr...
Switching to 'C' code...
Starting Microloader C...
Chip: APOLLO
Found External Realtek 8211EG PHY on GMAC0...
Waiting for flash downloading ...
Chip: APOLLO
Chip: APOLLO
GCS in ISA MODE
Jumping to U-Boot ...
9
| U-Boot 2009.08-00048-g19618f5 (Dec 24 2013 - 17:45:56) CST HDx |
| Chipset information |
| Vendor: NXP Type: Apollo Revision: M1 Fuses: 0015706B |
| Clock information |
| *** not available yet *** |
| Frontpanel information |
| Vendor: CST Version: 4.1 Display: OLED (256 x 64 px) |
| Memory configuration |
| 00000000*| 3FFFFFFF*| NAND | Toshiba TC58NVG3S0F 8G 3.3V 8-bit |
| Network configuration |
| MAC: LIP 6300 address: 00-C5-5C-29-BB-32 |
3145728 bytes read: OK
Image Name: NI Apollo Kernel
Data Size: 2971088 Bytes = 2.8 MB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
[ 0.000000] Linux version 3.10.93 (neutrino-images@nisrv) (gcc version 6.3.1 20170109 (crosstool-NG crosstool-ng-1.23.0-36-g1dbb06f2-dirty) ) #1 SMP Tue Dec 8 00:23:57 CET 2020
[ 0.000000] PERCPU: Embedded 7 pages/cpu @80910000 s5952 r8192 d14528 u32768
[ 0.000000] Kernel command line: noinitrd console=ttyS0,115200n8 mtdparts=nx_sfc:256k@0k(uldr),512k@256k(u-boot),128k@768k(env),128k@896k(spare),-(kernel);nx_2017:256m@0k(root0),32m@256m(var),-(root1) root=mtd:root0 rootfstype=jffs2 rootflags=noatime rw
[ 0.000000] Memory: 246960k/246960k available, 277328k reserved, 0K highmem
[ 0.000000] .text : 0x80008000 - 0x80679dc4 (6600 kB)
[ 0.000000] .init : 0x8067a000 - 0x806a9740 ( 190 kB)
[ 0.000000] .data : 0x806aa000 - 0x806ebd60 ( 264 kB)
[ 0.000000] .bss : 0x806ebd60 - 0x80707424 ( 110 kB)
[ 0.000000] NR_IRQS:388
[ 0.253813] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.292713] pid_max: default: 32768 minimum: 301
[ 0.297594] Mount-cache hash table entries: 512
[ 0.304464] CPU: Testing write buffer coherency: ok
[ 0.309629] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.315286] Setting up static identity map for 0x803dd018 - 0x803dd070
[ 0.321853] L310 cache controller enabled
[ 0.325779] l2x0: 8 ways, CACHE_ID 0x410004c4, AUX_CTRL 0x32421001, Cache size: 131072 B
[ 0.334580] Brought up 1 CPUs
[ 0.337460] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.343700] CPU: All CPU(s) started in SVC mode.
[ 0.349176] devtmpfs: initialized
[ 0.360706] NET: Registered protocol family 16
[ 0.365844] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.519237] GMAC0: active interface is 6
[ 0.523171] ChipID=0x1 ChipRevID=0x2
[ 0.526781] nx_dmac: Registered with 8 channels
[ 0.536887] bio: create slab <bio-0> at 0
[ 0.541561] GPIO: base febd5000 (phys e06d5000)
[ 0.546222] GPIO: base feb69000 (phys e0669000)
[ 0.551276] SCSI subsystem initialized
[ 0.555438] usbcore: registered new interface driver usbfs
[ 0.560921] usbcore: registered new interface driver hub
[ 0.566265] usbcore: registered new device driver usb
[ 0.571360] pps_core: LinuxPPS API ver. 1 registered
[ 0.576222] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.585334] PTP clock support registered
[ 0.590332] cfg80211: Calling CRDA to update world regulatory domain
[ 0.597737] Switching to clocksource timer_us
[ 0.609893] NET: Registered protocol family 2
[ 0.615211] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.622306] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.628726] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.635051] TCP: reno registered
[ 0.638198] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.644041] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.650555] NET: Registered protocol family 1
[ 0.655201] RPC: Registered named UNIX socket transport module.
[ 0.661058] RPC: Registered udp transport module.
[ 0.665681] RPC: Registered tcp transport module.
[ 0.670357] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.676940] PM: STB Platform power mgmt initialization.
[ 0.825239] bounce pool size: 64 pages
[ 0.836187] NFS: Registering the id_resolver key type
[ 0.841267] Key type id_resolver registered
[ 0.845351] Key type id_legacy registered
[ 0.849341] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.855792] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.863238] msgmni has been set to 482
[ 0.868098] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.875438] io scheduler noop registered
[ 0.879271] io scheduler deadline registered
[ 0.883733] io scheduler cfq registered (default)
[ 0.888727] e06e2000.serial: ttyS0 at MMIO 0xe06e2000 (irq = 47) is a uart-ip3106
[ 0.900817] loop: module loaded
[ 0.904321] ahci-stb e0638000.sata: unable to find phy
[ 0.909369] SATA: Adjusting los_lvl (rd_val=0x8a46, wr_val=0x8ae6)
[ 0.915538] SATA: Adjusting rx_term_en0/1 (rd_val=0x2750275, wr_val=0x2770277)
[ 0.922727] ahci-stb e0638000.sata: SSS flag set, parallel bus scan disabled
[ 0.929700] ahci-stb e0638000.sata: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
[ 0.938515] ahci-stb e0638000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs
[ 0.949122] scsi0 : ahci_platform
[ 0.952776] scsi1 : ahci_platform
[ 0.956200] ata1: SATA max UDMA/133 mmio [mem 0xe0638000-0xe0638fff] port 0x100 irq 39
[ 0.964042] ata2: SATA max UDMA/133 mmio [mem 0xe0638000-0xe0638fff] port 0x180 irq 39
[ 0.972773] NAND device: Manufacturer ID: 0x98, Chip ID: 0xd3 (Toshiba TC58NVG3S0F 8G 3.3V 8-bit), 1024MiB, page size: 4096, OOB size: 232
[ 0.985661] Bad block table found at page 262080, version 0x01
[ 0.992067] Bad block table found at page 262016, version 0x01
[ 1.001485] JEDEC ID = 0x1c3016 , Extended Device ID = 0x1c30
[ 1.007235] nx_sfc e0632000.flash_sfc: en25q32 (4096 Kbytes)
[ 1.014111] tun: Universal TUN/TAP device driver, 1.6
[ 1.019065] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.025619] DWMAC1000
[ 1.027897] stmmac - user ID: 0x25, Synopsys ID: 0x35
[ 1.032950] Ring mode enabled
[ 1.035930] DMA HW capability register supported
[ 1.040443] Enhanced/Alternate descriptors
[ 1.044741] Enabled extended descriptors
[ 1.048717] RX Checksum Offload Engine supported (type 2)
[ 1.054172] TX Checksum insertion supported
[ 1.058393] Wake-Up On Lan supported
[ 1.062100] Enable RX Mitigation via HW Watchdog Timer
[ 1.070393] libphy: stmmac: probed
[ 1.073713] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.080122] eth%d: PHY ID 001cc915 at 5 IRQ POLL (stmmac-0:05)
[ 1.086504] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.092967] ehci-platform: EHCI generic platform driver
[ 1.098211] ehci-platform e066c000.usb: EHCI Host Controller
[ 1.103827] ehci-platform e066c000.usb: new USB bus registered, assigned bus number 1
[ 1.111692] ehci-platform e066c000.usb: irq 93, io mem 0xe066c000
[ 1.130147] ehci-platform e066c000.usb: USB 2.0 started, EHCI 1.00
[ 1.136305] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.143021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.150169] usb usb1: Product: EHCI Host Controller
[ 1.154994] usb usb1: Manufacturer: Linux 3.10.93 ehci_hcd
[ 1.160450] usb usb1: SerialNumber: e066c000.usb
[ 1.165657] hub 1-0:1.0: USB hub found
[ 1.169335] hub 1-0:1.0: 1 port detected
[ 1.173537] ehci-platform e066d000.usb: EHCI Host Controller
[ 1.179121] ehci-platform e066d000.usb: new USB bus registered, assigned bus number 2
[ 1.187035] ehci-platform e066d000.usb: irq 94, io mem 0xe066d000
[ 1.210091] ehci-platform e066d000.usb: USB 2.0 started, EHCI 1.00
[ 1.216246] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.222951] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.230105] usb usb2: Product: EHCI Host Controller
[ 1.234932] usb usb2: Manufacturer: Linux 3.10.93 ehci_hcd
[ 1.240385] usb usb2: SerialNumber: e066d000.usb
[ 1.245575] hub 2-0:1.0: USB hub found
[ 1.249249] hub 2-0:1.0: 1 port detected
[ 1.253596] usbcore: registered new interface driver usb-storage
[ 1.259661] usbcore: registered new interface driver usbserial
[ 1.266093] sdhci: Secure Digital Host Controller Interface driver
[ 1.272209] sdhci: Copyright(c) Pierre Ossman
[ 1.276565] stb-sdhci e0635000.sdhci: SDHC/MMC controller IP_3413 Version is 0x75
[ 1.284051] stb-sdhci e0635000.sdhci: SDHC/MMC controller IP_3413 found @ [feb35000] (rev 7501)
[ 1.340088] mmc0: SDHCI controller on IP_3413 [e0635000.sdhci] using ADMA
[ 1.347077] usbcore: registered new interface driver usbhid
[ 1.352585] usbhid: USB HID core driver
[ 1.356670] TCP: cubic registered
[ 1.359901] NET: Registered protocol family 17
[ 1.364536] Key type dns_resolver registered
[ 1.368841] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 1
[ 1.376383] ThumbEE CPU extension supported.
[ 1.381913] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.387903] ### dt-test ### No testcase data in device tree; not running tests
[ 1.600095] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.730104] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.735662] MTD: MTD device with name "root0" not found.
[ 1.740956] VFS: Cannot open root device "mtd:root0" or unknown-block(0,0): error -2
[ 1.748585] Please append a correct "root=" boot option; here are the available partitions:
[ 1.756932] 1f00 1048576 mtdblock0 (driver?)
[ 1.761898] 1f01 4096 mtdblock1 (driver?)
[ 1.766906] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.775118] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.93 #1
[ 1.781125] [<80014058>] (unwind_backtrace+0x0/0xe8) from [<80011128>] (show_stack+0x10/0x14)
[ 1.789562] [<80011128>] (show_stack+0x10/0x14) from [<803d3e40>] (panic+0xa0/0x1ec)
[ 1.797254] [<803d3e40>] (panic+0xa0/0x1ec) from [<8067b090>] (mount_block_root+0x1e8/0x290)
[ 1.805624] [<8067b090>] (mount_block_root+0x1e8/0x290) from [<8067b2e8>] (prepare_namespace+0x9c/0x188)
[ 1.815040] [<8067b2e8>] (prepare_namespace+0x9c/0x188) from [<8067ad08>] (kernel_init_freeable+0x224/0x234)
[ 1.824818] [<8067ad08>] (kernel_init_freeable+0x224/0x234) from [<803cf190>] (kernel_init+0xc/0x150)
[ 1.833963] [<803cf190>] (kernel_init+0xc/0x150) from [<8000da60>] (ret_from_fork+0x14/0x34)
Chip: APOLLO
Chip: APOLLO
GCS in ISA MODE
9
| Clock information |
Emergency update from usb
(Re)start USB...
USB EHCI 1.00
reading uldr.bin
** Skipping uldr.bin **
reading u-boot.bin
** Skipping u-boot.bin **
reading vmlinux.ub.gz
2971152 bytes read
OK
3145728 bytes written: OK
reading rootfs.arm.jffs2.nand
57731952 bytes read
NAND erase: device 0 offset 0x0, size 0x10000000
Erasing at 0xffc0000 -- 100% complete.
OK
NAND write: device 0 offset 0x0, size 0x370eb70
57731952 bytes written: OK
reading appfs.jffs2.nand
** Unable to read "appfs.jffs2.nand" from usb 0:1 **
** Skipping appfs.arm.jffs2.nand **
reading appfs1.jffs2.nand
** Unable to read "appfs1.jffs2.nand" from usb 0:1 **
** Skipping appfs1.arm.jffs2.nand **
reading extra.nand
** Unable to read "extra.nand" from usb 0:1 **
** Skipping extra.nand **
resetting ...
Chip: APOLLO
GCS in ISA MODE
9
| Clock information |
OK
[ 0.253805] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.297598] Mount-cache hash table entries: 512
[ 0.304482] CPU: Testing write buffer coherency: ok
[ 0.309634] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.315288] Setting up static identity map for 0x803dd018 - 0x803dd070
[ 0.325780] l2x0: 8 ways, CACHE_ID 0x410004c4, AUX_CTRL 0x32421001, Cache size: 131072 B
[ 0.334584] Brought up 1 CPUs
[ 0.343701] CPU: All CPU(s) started in SVC mode.
[ 0.349170] devtmpfs: initialized
[ 0.360673] NET: Registered protocol family 16
[ 0.365808] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.519201] GMAC0: active interface is 6
[ 0.523137] ChipID=0x1 ChipRevID=0x2
[ 0.526747] nx_dmac: Registered with 8 channels
[ 0.536831] bio: create slab <bio-0> at 0
[ 0.541503] GPIO: base febd5000 (phys e06d5000)
[ 0.546174] GPIO: base feb69000 (phys e0669000)
[ 0.551233] SCSI subsystem initialized
[ 0.555394] usbcore: registered new interface driver usbfs
[ 0.560881] usbcore: registered new interface driver hub
[ 0.566221] usbcore: registered new device driver usb
[ 0.571318] pps_core: LinuxPPS API ver. 1 registered
[ 0.576180] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.585291] PTP clock support registered
[ 0.590284] cfg80211: Calling CRDA to update world regulatory domain
[ 0.597693] Switching to clocksource timer_us
[ 0.609853] NET: Registered protocol family 2
[ 0.615178] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.622273] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.628701] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.635033] TCP: reno registered
[ 0.638183] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.644027] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.650540] NET: Registered protocol family 1
[ 0.655193] RPC: Registered named UNIX socket transport module.
[ 0.661049] RPC: Registered udp transport module.
[ 0.665673] RPC: Registered tcp transport module.
[ 0.670350] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.676932] PM: STB Platform power mgmt initialization.
[ 0.825173] bounce pool size: 64 pages
[ 0.836096] NFS: Registering the id_resolver key type
[ 0.841147] Key type id_resolver registered
[ 0.845230] Key type id_legacy registered
[ 0.849220] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.855675] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.863120] msgmni has been set to 482
[ 0.867984] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.875330] io scheduler noop registered
[ 0.879160] io scheduler deadline registered
[ 0.883622] io scheduler cfq registered (default)
[ 0.888614] e06e2000.serial: ttyS0 at MMIO 0xe06e2000 (irq = 47) is a uart-ip3106
[ 0.900701] loop: module loaded
[ 0.904210] ahci-stb e0638000.sata: unable to find phy
[ 0.909257] SATA: Adjusting los_lvl (rd_val=0x8a46, wr_val=0x8ae6)
[ 0.915426] SATA: Adjusting rx_term_en0/1 (rd_val=0x2750275, wr_val=0x2770277)
[ 0.922613] ahci-stb e0638000.sata: SSS flag set, parallel bus scan disabled
[ 0.929588] ahci-stb e0638000.sata: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
[ 0.938403] ahci-stb e0638000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc sxs
[ 0.949016] scsi0 : ahci_platform
[ 0.952665] scsi1 : ahci_platform
[ 0.956098] ata1: SATA max UDMA/133 mmio [mem 0xe0638000-0xe0638fff] port 0x100 irq 39
[ 0.963939] ata2: SATA max UDMA/133 mmio [mem 0xe0638000-0xe0638fff] port 0x180 irq 39
[ 0.972675] NAND device: Manufacturer ID: 0x98, Chip ID: 0xd3 (Toshiba TC58NVG3S0F 8G 3.3V 8-bit), 1024MiB, page size: 4096, OOB size: 232
[ 0.985555] Bad block table found at page 262080, version 0x01
[ 0.991956] Bad block table found at page 262016, version 0x01
[ 1.001373] JEDEC ID = 0x1c3016 , Extended Device ID = 0x1c30
[ 1.007124] nx_sfc e0632000.flash_sfc: en25q32 (4096 Kbytes)
[ 1.014015] tun: Universal TUN/TAP device driver, 1.6
[ 1.018972] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.025524] DWMAC1000
[ 1.027802] stmmac - user ID: 0x25, Synopsys ID: 0x35
[ 1.032854] Ring mode enabled
[ 1.035836] DMA HW capability register supported
[ 1.040349] Enhanced/Alternate descriptors
[ 1.044647] Enabled extended descriptors
[ 1.048624] RX Checksum Offload Engine supported (type 2)
[ 1.054079] TX Checksum insertion supported
[ 1.058299] Wake-Up On Lan supported
[ 1.062005] Enable RX Mitigation via HW Watchdog Timer
[ 1.070291] libphy: stmmac: probed
[ 1.073608] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.079999] eth%d: PHY ID 001cc915 at 5 IRQ POLL (stmmac-0:05)
[ 1.086433] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.092893] ehci-platform: EHCI generic platform driver
[ 1.098141] ehci-platform e066c000.usb: EHCI Host Controller
[ 1.103758] ehci-platform e066c000.usb: new USB bus registered, assigned bus number 1
[ 1.111625] ehci-platform e066c000.usb: irq 93, io mem 0xe066c000
[ 1.136309] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.143024] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.150170] usb usb1: Product: EHCI Host Controller
[ 1.154995] usb usb1: Manufacturer: Linux 3.10.93 ehci_hcd
[ 1.160451] usb usb1: SerialNumber: e066c000.usb
[ 1.165658] hub 1-0:1.0: USB hub found
[ 1.169333] hub 1-0:1.0: 1 port detected
[ 1.173538] ehci-platform e066d000.usb: EHCI Host Controller
[ 1.179122] ehci-platform e066d000.usb: new USB bus registered, assigned bus number 2
[ 1.187037] ehci-platform e066d000.usb: irq 94, io mem 0xe066d000
[ 1.216247] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.222949] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.234933] usb usb2: Manufacturer: Linux 3.10.93 ehci_hcd
[ 1.240386] usb usb2: SerialNumber: e066d000.usb
[ 1.245573] hub 2-0:1.0: USB hub found
[ 1.249247] hub 2-0:1.0: 1 port detected
[ 1.253597] usbcore: registered new interface driver usb-storage
[ 1.259662] usbcore: registered new interface driver usbserial
[ 1.266104] sdhci: Secure Digital Host Controller Interface driver
[ 1.272217] sdhci: Copyright(c) Pierre Ossman
[ 1.276574] stb-sdhci e0635000.sdhci: SDHC/MMC controller IP_3413 Version is 0x75
[ 1.284059] stb-sdhci e0635000.sdhci: SDHC/MMC controller IP_3413 found @ [feb35000] (rev 7501)
[ 1.347078] usbcore: registered new interface driver usbhid
[ 1.352588] usbhid: USB HID core driver
[ 1.356667] TCP: cubic registered
[ 1.359893] NET: Registered protocol family 17
[ 1.368842] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 1
[ 1.376385] ThumbEE CPU extension supported.
[ 1.381912] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.387905] ### dt-test ### No testcase data in device tree; not running tests
[ 1.600094] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.730103] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.735664] MTD: MTD device with name "root0" not found.
[ 1.740969] VFS: Cannot open root device "mtd:root0" or unknown-block(0,0): error -2
[ 1.748593] Please append a correct "root=" boot option; here are the available partitions:
[ 1.756941] 1f00 1048576 mtdblock0 (driver?)
[ 1.761908] 1f01 4096 mtdblock1 (driver?)
[ 1.766915] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.775127] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.93 #1
[ 1.781133] [<80014058>] (unwind_backtrace+0x0/0xe8) from [<80011128>] (show_stack+0x10/0x14)
[ 1.789570] [<80011128>] (show_stack+0x10/0x14) from [<803d3e40>] (panic+0xa0/0x1ec)
[ 1.797264] [<803d3e40>] (panic+0xa0/0x1ec) from [<8067b090>] (mount_block_root+0x1e8/0x290)
[ 1.805633] [<8067b090>] (mount_block_root+0x1e8/0x290) from [<8067b2e8>] (prepare_namespace+0x9c/0x188)
[ 1.815049] [<8067b2e8>] (prepare_namespace+0x9c/0x188) from [<8067ad08>] (kernel_init_freeable+0x224/0x234)
[ 1.824829] [<8067ad08>] (kernel_init_freeable+0x224/0x234) from [<803cf190>] (kernel_init+0xc/0x150)
[ 1.833972] [<803cf190>] (kernel_init+0xc/0x150) from [<8000da60>] (ret_from_fork+0x14/0x34)
Re: Starting (Emergency Flash)
Du hast ein Image mit nicht passenden Kernel
Update von Kernel und Image hat eigentlich funktioniert
Kernel:
2971152 bytes read
OK
Image:
57731952 bytes read
OK
Ich würde mal ein aktuelles Image nehmen.
Ob die Bad blocks das Image kaputt machen k.A.
Wenn du da nicht weiter kommst kannst du auch ein 2. Image in die 2. Partition flashen,
das muß auf dem Stick dann rootfs1.arm.jffs2.nand heißem.
Auswählen nachher beim Start war glaube ich die Menütaste, sieht man im Display....
Been thanked: 40 times
Re: Starting (Emergency Fash)
die "Bad Blocks" sind normal, das ist OK so.
Flashe mal noch den uldr und uboot mit, gehe also nach dieser Anleitung vor (hast du ja quasi schon):
coolstream-hd2-f48/hd2-alle-boxen-recov ... -t135.html
Dort bitte den 2. Beitrag beachten, in dem Link dort holst du dir dann noch den Anhang für "Apollo (Tank/Trinity)" und packst die uldr.bin und u-boot.bin daraus mit auf den Stick und flashst alles zusammen nochmal. Bitte wieder mitloggen und wenn es nicht klappt, bitte dieses Log posten.
Die leere env.bin hast du ja schon mit auf dem Stick nehme ich an? Die ist nämlich evtl auch wichtig jetzt.
Zurück zu „Apollo (TANK)“
